Question about GE GSH25JFT
GE GSH25JFTA BB getting VERY warm on defrost
My GE Fridge, Model GSH25JFTA BB is getting VERY warm during defrost. Everything thaws, then re-freezes. The ice in the ice bin melts & re-freezes into an almost solid chunk, ice cream pools in the carton & re-freezes, etc. I replaced the thermistor, no change. The defroster is getting warm enough that's it's 'rippled' the seal on the sides of the back panel! After lots of reading, I'm guessing I need a new mother board-?? Any advice? And how do I check this? Thank you!
  • 1 more comment
  • Tony Muller May 29, 2010
    Thank you! I see now I made a mistake... the thermostat has been replaced (to no avail), NOT the thermistor. How do I check the thermistor; or do you suspect the mother board is the problem?
    Thank you again for taking the time to clearly explain this! Armed with your info, I'll get on the (hopeful) repair today!! Now... I'm assuming that if either of these are 'bad', I can simply replace them? And if they're 'good', I need to get a new board, right? (assuming solder joints all check out OK)
  • Tony Muller Oct 24, 2010
    OK, it's been several months, and we've been using the fridge side only, but I'm really stumped. Here's a quick run-down:
    Checked thermistor
    President:
  • 1,218 Answers
Good day,
Your machine should have a limit thermostat as well as the thermister. It may payto change it first before the motherboard.
It looks like this, mounted on the top of the coil.
If that fails, and the machine goes back to normal cooling until the next defrost cycle, I can think of nothing but the motherboard as the culprit.
Posted on May 29, 2010
  • John Hall May 29, 2010
    Here's the value of the Thermister. It must be tested in a water/ice solution at 32 degrees.
    Thermister for ge refrigerators
    WR55X10025
    in icewater 16,600 ohms + - 5%
    At the price, I would change the one on the top of the coil and and on the bottom center.
    Unfortunately, all the components in this machine interact to such a degree that one can test and get the wrong answer anyway.
    Once the thermistors are changed, only testing over a period of time will tell if changing the motherboard is necessary.
    Scholar:
  • 59 Answers
Look at the drawing below. #240 is the defrost thermostat and it clips near the top of the coils of the freezer. It is about the diameter of a quarter and has 2 wires coming out of it. Its job is to reach a certain temperature and then cut the power to the defrost heater. To check it you will need for it to be cold and then use an ohm meter to read ohms through the 2 wires coming from it while it is disconnected from the circuit. Hold it in your hand until you feel it click and then you should not be able to get a reading through it. A normal failure of this part is exactly opposite of what you are describing but it is the control that allows power to the heater.
What you are describing does sound more like the main board going bad. Sometimes when it cycles on to cool you can hear a clicking from the board but not always. I also have found some loose solder joints on the relays on that board. Be aware if your going to look at it the unit needs to be unplugged as 110 volts will be present.
Here are the part numbers.
Defrost thermostat is WR50X10068
The board is WR55X10942
Testimonial: "Thanks for the very helpful (& FAST!) response & photo! I was incorrect in my original posting - the thermostat has been replaced (not thermistor), which didn't change anything. I'll check solder joints on the mother board as you mentioned. Thank you SO much!"
  • 1 more comment
  • Gene c May 29, 2010
    I am looking to be see how many thermistors are in your unit unless Jackfrost gets it on before I do.
    Thanks
    I cannot really get the scan as clear as I want. If you open the control panel in the fridge side you should be able to find the drawing for your unit. It should be inside the panel where the controls are. On this particular unit for example there are 3 thermistors and they connect to the motherboard in the connector with the arrow drawn to it. Take a thermistor in the freezer there is one at the lower left corner and I think one about halfway up in the wall on the side and drop it in some ice water. Look at your drawing to find the pins on YOUR drawing. Reading ohms across the 2 thermistor pins it should read between 7 and 10k ohms. You will only need to test the 2 in the freezer.
    I agree with that statement.
Water in side by side door stopped working ?
got a problem alright
water may have got to the electrics
needs a GE authorized repairer to check
safety first
turn wall power switch off and unplug from wall
if desperate buy some bagged ice to preserve fridge contents
Oct 14, 2016 | GE Refrigerators
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
GE GSH25JFTA refrigerator has stopped dispensing water. Ice is OK
change the tempt of freezer if too cold it will freeze line . try seting it for 5 to 20 deg some run below 0 and will freeze the water .. mm
Jul 29, 2010 | GE Refrigerators
GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Mar 02, 2010 | GE GSH25JFT
Top of refrigerator is warm and bottom freezes everything it is a side by side refrigerator and the top two shelves of the freezer(along with the icemaker) thaw and melt but the bottom freezes and the top...
poss answer is drain hole/vent blocked,as unit auto defrosts water/vapour collects at bottom and when unit swiches back on it freezes,poke out drain with thin wire with a small piece of cloth dipped in clorine bleach or blow out with air hose.do not use hot water to manually defrost/ clean drain holes every 6 months
Feb 07, 2010 | Refrigerators
Freezer not freezing & fridge warm at top and freezing at bottom.
Check and see if you have a fan that is not working. A condenser fan might just be your problem. The air is not circulating right. If this isn't the solution try turning the frig off for a couple of hours to see if it will correct the problem. BB
Dec 15, 2009 | GE GSS22SGPSS Side by Side Refrigerator
Freezer coils freeze up then frig warms
this is more than likely a defrost sensor or timer that is not allowing the fridge to go into a defrost mode.you could also have a problem with the thermastat the allows the fridge to run for longer periods of time.
Sep 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Apr 08, 2009 | GE Refrigerators
Defrost cycle
You night need to replace the 'Defrost Thermostat'
Aug 06, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE GSH25JFT Logo
1,168 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
