Question about Fuji FinePix A800 Digital Camera
Hi, i have a A850, error reads "zoom error"
Is there a resolution to this problem? I power on the message appears and the zoom shuts with a red flashing LED below the "W" on the zoom. Thanks
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
My laptop is zoomed out way to far and i cant even read the words or anything. how do i fix this?
Hi georginabale...
Try to adjust your screen resolution and see if that helps
Click Start>Control Panel>Appearance and Themes>Change the Screen Resolution.
When the window opens try using the slider in one direction and then the other to see if that solves your problem.
Note: give it a minute to get to the resolution after you have clicked on it.
Please take time to rate me
Sep 01, 2011 | HP Mini 1000 Netbook
Not always but most of the time , after working propely i can ear the fan(s) going stronger for few seconds, a message "ERROR MESSAGE CONDITION2" appear , the TV(monitor) shut down, and the power...
hi,
check the fans first. i may have some problem. i think the fan may be not attaining its regular speed. it can happens because of the wear and tear of the bearing of the fan. thats why the temperature is going up and shut the tv off. replace the fan and then try again.
ok
Dec 31, 2010 | Fujitsu Plasmavision PDS-5002 50 in....
Error read - message given when I try scroll through pictures taken. Can only see the first picture then the "error read" appears
I had this problem! just solved it by erasing all the photos off the card (or reformat it) hopes this helps!
Oct 16, 2009 | Fuji FinePix E900 Zoom Digital Camera
Zoom Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 16, 2009 | Canon PowerShot A85 Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Fuji FinePix A800 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
