Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Whats the valves set at on a tb475ss weed eater
  • 61 Answers
Exaust is set to .013 to .016,,,,,,
intake is set to .oo3 to .006......
i hope this does the job for you,,,good luck
Posted on May 29, 2010
Missing power cord to weed eater what can i use to power it up?
Most electric weed whacked use an extension cord....just plug the end into the weed eater
Oct 07, 2016 | Garden
Weed Eater Priming
Check out the tubing to the carb. If it is good then the top part of the carb with the check valves is defective. If so, you need a new carb since those suckers cannot be fixed.
Aug 21, 2016 | Craftsman Weed Wacker Lawn Edgers
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Ss30 ryobi weed eater fuel ratio
    I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
    Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
    My weed eater starts but won't stay running. what
    Try a new spark plug.Thanks for asking and I hope it helps
    Jul 19, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    Powerpro 17" McCollich weed eater
    hey harry the float inside the carb is stuck i would suggest rebuilding the carb
    Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    WEED EATER STRING
    you have the string in backwards, or the gear is not ingauged.
    Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
    Poulan Weed Eater Trim Line Constantly Jams
    Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
    Jim
    Jun 13, 2009 | Poulan Garden
    Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
    427 people viewed this question
    Top Troy Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    DROPNDEAL
    DROPNDEAL
    Are you a Troy Garden Expert? Answer questions, earn points and help others
