Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Sensor I need a part number for the above sensor and a manual on how to install it
    Habit-Forming:
  • 77 Answers
Which sensor??? There are at least 2 sensors on your hot tub.
You wont find a manual telling you how to change the sensor (at least not from the manufacturers).
Regards,
Ian, from http://hottub.synthasite.com
Posted on Jun 18, 2010
Testimonial: "Thank you so much. It was easy to figure out once I opened the door and followed the wiring to the sensor. "
P0421 code
"FWIW, according to the Mazda factory service manual, the P0421 code indicates "Warm up catalyst system efficiency below threshold".
The DETECTION CONDITION for this code indicates "Number of heated oxygen sensor (rear) inversion becomes closer to that of heated oxygen sensor (front)".
POSSIBLE CAUSES are:
Warm up three way catalytic converter deterioration
Leakage exhaust system
Heated oxygen sensor (front) malfunction
Heated oxygen sensor (rear) malfunction
Mass air flow sensor malfunction
Throttle position sensor malfunction
Vehicle speed sensor malfunction"
I copied the above from a discussion group on the PO421 code. The code can be caused by any of the above listed problems. The vehicle should be further inspected and diagnosed, so you do not have components replaced that do not need to be replaced.
Apr 16, 2014 | 1998 Mazda 626
Code 21,43,and 42
You have two oxygen sensors but 21 is upstream sensor. This is the sensor between engine and catalytic converter. There is three possible problems that it could be.
1 oxygen sensor input voltage maintained above the normal operating range.
2 no signal at 02 2/1 sensor
3 oxygen sensor input voltage sustained above thenormal operating range. What all this means is you need to replace the sensor.
when getting the replacement this is your O2 2/1 sensor.
May 13, 2013 | 1996 Jeep Cherokee Country
Engine stalls, p0720 engine light on. Runs ok than goes sporadic.
There are 2 possibilities here:
1.- There may be a problem with the new speed sensor, the electrical wiring between the speed sensor and the PCM, or an internal PCM problem. To see if VSS signal is present at the PCM a scan tool capable of displaying live data is required.
2.- There is a recall action on this model year for erroneous speed sensor signals; the cure is an updated software calibration. If your truck has not yet had the updated calibration installed, you should call your local Dodge dealership with your VIN number and ask the service department to check to see if there are any open recall actions on your vehicle. If the software calibration has not been updated yet, they will perform this procedure free of charge for you. If you do not have the current software calibration in your PCM to correct the VSS issue, you need to have this done before proceeding any further with attempting to diagnose this problem
This sensor is located at the rear of the transmission.
Symptom: P-0720 LOW OUTPUT SPEED SENSOR RPM, ABOVE 15 MPH
When Monitored and Set Condition: P-0720 LOW OUTPUT SPEED SENSOR RPM, ABOVE 15 MPH
When Monitored: Continuously with the key on, engine running, and gear selector not in park or neutral.
Set Condition: This code is set if the vehicle speed (as determined from the vehicle speed sensor), is above 15 MPH, and the output shaft speed is below 60 RPM for 2.6 seconds.
POSSIBLE CAUSES DTC CODE RETURNS:
OUTPUT SPEED SENSOR DEFECTIVE
PARK/NEUTRAL SWITCH CODE PRESENT
OUTPUT SPEED SENSOR GROUND CIRCUIT OPEN
OUTPUT SPEED SENSOR GROUND CIRCUIT SHORT TO GROUND
OUTPUT SPEED SENSOR SIGNAL CIRCUIT OPEN
OUTPUT SPEED SENSOR SIGNAL CIRCUIT SHORT TO GROUND
PCM DEFECTIVE (DRB SHOWS > 60 RPM)
OUTPUT SPEED SENSOR HARNESS OBSERVABLE DEFECT
OUTPUT SPEED SENSOR WIRING HARNESS INTERMITTENT DEFECTIVE
Hope helps.
Sep 14, 2011 | Dodge Ram 1500 Cars & Trucks
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
I need a spark plug for a 5700 watt 11 hp generator, which one do I need?
Hi and welcome to FixYa. I am Kelly.
The standard plug is an NGK "BPR5ES" or Denso "W16EPR-U" There are a number of alternate plugs out there if you use the number above in a cross reference book.
One thing to note... the generator has a "Low Oil" sensor and if the oil level is low you will not see any spark. If after you install a new plug and you still do not have spark... un-hook one wire from the low oil level sensor and check spark again. If you unhook the sensor wire knowing full well the oil level is full.and have spark; the sensor is either dirty or bad.
Thanks for choosing FixYa,
Kelly
Feb 19, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
Please i want to know my subaru impreza 2006,s diagnosis code numbers
Here is a list of Subaru diagnosis codes. If these are not what you are coming up with let me know the numbers you are getting and I will look them up on my genisys scanner to further assist you.
1111 No codes stored
11 Crankshaft position sensor (Don't confuse with above, usually when the crankshaft sensor if dodgy the thing won't start anyway)
12 Starter switch faulty
13 Camshaft position sensor
14 Injector no.1
15 Injector no.2
16 Injector no.3
17 Injector No.4
21 Engine temp sensor
22 Knock sensor
23 Mass air flow sensor
24 Idle air control sensor (usually accompanied by running too fast/slow)
31 Throttle position sensor
32 O2 sensor
33 Vehicle speed sensor
35 Emissions canister purge valve
38 Torque control signal (Automatics)
42 Closed throttle position
44 Turbo wastegate regulator malfunction
45 MAP sensor
49 CO adjustment resistor for older cars not fitted with cats
51 Neutral switch (Manual gearbox)
Feb 08, 2011 | 2007 Subaru Impreza WRX STI Limited Sedan
I need to put a crankshaft sensor but I don't Know its location I already changed the cam sensor. Ronnie
The crank sensor is located on the engine near the flywheel axis of the crankshaft.
Crankshaft Position Sensor Removal & Installation To Remove:
Location of the crankshaft position sensor on the 3.3L and 3.8L engines 91154g21.gif
NOTE: On the 2.4L engine, the crankshaft position sensor is mounted to the engine block behind the alternator, just above the oil filter. On the 3.0L, 3.3L and 3.8L engines, the crankshaft position sensor is mounted on the transaxle housing, above the vehicle speed sensor.
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Disconnect the crankshaft position sensor electrical connector.
  4. Unfasten the sensor mounting screw, then remove the sensor from the vehicle by pulling it straight out.
To Install:
NOTE: If the sensor removed is going to be re-installed, clean off the old spacer on the sensor face. A new spacer must be attached to the sensor face before installation. If the sensor is being replaced, be sure that a paper spacer is attached to the sensor face.
  1. Install sensor and push the sensor in until contact is made. While holding the sensor in this position, install and tighten the mounting bolt to 105 in. lbs. (12 Nm).
  2. Connect the crankshaft position sensor electrical connector.
  3. Lower the vehicle.
  4. Connect the negative battery cable.
Jul 31, 2010 | 1996 Plymouth Grand Voyager
Where is the input speed sensor 2002 pt cruiser po715 is the number on the palm reader
The input speed sensor is just under$30.00 at the dealer and it should take you less time to replace it then to find it. The sensor is on the transmission under the battery tray closes to the engine. There are two sensors and the other one is the vehicle velocity sensor which is the one furthest from the engine block. Your going to need a 1' socket to remove the sensor and extension and a swivel. Find the solenoid pack connector on the transmission which is under the battery tray and right above that should be the input sensor. Un-clip the wire lead to the sensor and remove the sensor, install new sensor and re-clip the wire lead and re-install anything you need to remove to get to the sensor. Good luck and keep me posted, it may be easier to go from the bottom of the cruiser.
Nov 04, 2009 | 2002 Chrysler PT Cruiser
Oxygen sensor
you need to borrow the oxygen sensor wrench from autozone or whereever you bought the sensor. Section 03-14: Engine Controls, Electronic 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION -------------------------------------------------------------------------------- Heated Oxygen Sensor (HO2S) SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Oxygen Sensor Wrench T94P-9472-A Removal and Installation Disconnect battery ground cable (14301). Refer to Section 14-01 . On 3.0L (4V) engine remove cowl extension and right side of leaf screen. Disconnect engine control sensor wiring (12A581) from heated oxygen sensors (HO2S) (9F472). Do not remove harness connectors from the brackets. Raise vehicle on hoist. Refer to Section 00-02 . NOTE: If excessive force is needed to remove a heated oxygen sensor, lubricate the heated oxygen sensor with penetrating oil prior to removal. Remove heated oxygen sensors from exhaust manifolds (9430) using Oxygen Sensor Wrench T94P-9472-A. To install, reverse Removal procedure. Apply a coating of anti-sieze compound to threads of heated oxygen sensor. Tighten heated oxygen sensors to 34-46 Nm (26-34 lb-ft).
Jun 13, 2009 | 1996 Ford Taurus
GE Simon 3 Add or Change a Sensor to my system?
You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
Oct 06, 2008 | GE Security Simon 3 Wireless Home Security...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
529 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
