Question about Belkin N Wireless Modem-Router F5D8633au4A
Have a belkin N wireless router - no wireless
Hi
Works ok with ethernet cable and recognises my network when wireless but won't connect (network say 'local only')?
Please help
    Guru:
  • 523 Answers
Hi Friend,
Please restart the laptop and try again
Regards,
Aysaam
Posted on Jun 09, 2010
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
I've got a DG834 connected to my computer - this has been working ok for several years. I now am trying to add a Canon Pixma MX870 to the network. But i can't get the network to recognise that I've added...
If you can connect it directly using an ethernet cable first, ensure it works OK, then do it wirelessly, it should start connecting correctly.
If not, remove the security settings for wireless connection. Go through the procedure of connecting wirelessly, once connected, enter in security settings for wireless connection again.
Jan 08, 2011 | NetGear DG834G Router
My router works when connected as wireless, but when I connect an ethernet cable to this, it does not work. This is required as I am trying to connect a network hard drive via the ethernet connection.
Hi. I suggest you double check first if the ethernet cable you're using is a known good cable if yes then that should be on your router configuration that enables you to use the ethernet cable, so I think you need to contact your Internet Service Provider regarding this matter because by default you should have the access using the ethernet cable, and they'll be the one to configure your router. Hope this helps
Jun 04, 2010 | Belkin (F5D7230-4) Router (587009)
My Belkin wireless router isn't being recognised by my computer,is there a way to fix this without the CD?
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Click Here for step by step solution
Apr 30, 2010 | Belkin (F5D5231-4) Router
The router connects via ethernet and works fine but does not release a wireless connection. I am constantly using Ethernet when i desired to use wirelessely?
first delete all the preferred networks....
now scan for the wireless networks in the range...
select your network and click connect....
uncheck the checkbox "connect automatically if this device is in range"....click ok....
your problem will be solved now...
pls do rate if its useful...
you can also go to preferred networks list and edit the settings stored in the computer...
Apr 03, 2010 | Belkin F5D8236-4 Router
UNABLE TO PASSWORD BELKIN ROUTER
OK, I want you to remove the power and then find the little hole at rear and reset this unit, this will reset to factory, specs. Now try to reset again. You will have to re-set it up all again..Do it with a wired connection through the Ethernet port. in case you don't have a manual have included a link below... have a refresher look, perhaps you are overlooking something? en-us-support.belkin.com/app/answers/detail/a_id/355
Mar 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I set up my laptop using a Belkin wireless router, and it is o.k. thro ethernet by does not recognise wireless when I disconnect the ethernet cable!!
Well the best shot is to reset the router back to factory by pressing the reset button for 10 seconds then it will flash a couple of times. then see if your laptop can connect to the router, If that doesnt work let me know
Nov 22, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My wireless on my f5d7230-4 won't work but when i hook up a ethernet cable from the wireless router to my laptop the internet works but my wireless will not work
With the ethernet cable , it is working, Ok the router wired part is working but the wireless part is not working.
on your laptop , does it say connected to your wireless network ?
If it is not then try to connect to the wireless network .
Make sure that you have the correct wireless settings of the router .
Click Here for step by step solutions
Nov 12, 2009 | Belkin (F5D7230-4) Router (587009)
Trouble connecting wireless
first thing to do is to dissable the ethernet connection in network connections on your notebook so as the ip address does not conflict.
assuming it's XP and assuming DHCP is enabled in the router settings, right click on your wireless conection in network connections, properties>TCP/IP line, highlight it and then click properties again, then ensure obtain an ip address automatically is ticked, apply and ok, close window.
If neccasary run the wireless network wizard in new connections in network connections.
Open internet explorer>tools>internet options>connections tab and ensure that 'never dial a connection' is ticked, ok and close IE.
Open IE and click refresh a few times.
Sep 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N Wireless Modem-Router F5D8633au4A Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
