Question about Jenn-Air JED8230 Electric Cooktop
Our Jenn Air electric cooktop model JEC 0530 is not working as one of the touch burners will not respond to touch. How can this sensor be fixed?
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
Eddie Rentas
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
SOURCE: Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Posted on Aug 13, 2008
mgprice
  • 744 Answers
SOURCE: Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
Posted on Jun 26, 2009
  • 222 Answers
SOURCE: Front double burner not working on Jenn Air
mostly the problem is the sensor inside the unit but so very expensive to replace,wait to damage the other then buy an new one compare to repair.
tnx gerbee
Posted on Jul 04, 2009
My jenn-air 8430 cooktop left front burner cycles off-on in the HIGH position. What could be wrong?
I am assuming your cooktop is electric and your have a glass top, if so the burners sensor is bad and you might need to replace the burner. Again before buying anything and for me to help you, I would need a full model number. Some model have plate sensors and with no plate/pot burner cycles. Most of the time I find the sensor in the burner cant detect the heat and this ends up being a safety issue to protect the unit. All this information is based on the premise you have an electric cooktop and a glass surface.
I hope this helps.
Oct 16, 2013 | Jenn-Air Cooktops
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
One of the four burners does not work. The light comes on but no heat. Can it be repaired?
Yes, you have a bad burner, sensor, burner switch, or wiring problem. The most likely is the burner switch. You should get this repaired asap, as this could be shorting out inside, and cause an electrical shock hazard. Unlikely but enough of a possibility that you should fix it soon.
Jan 29, 2010 | Jenn-Air JED8430 Electric Cooktop
ONE OF THE FOUR TOUCH PADS DOES NOT RESPOND
JED 8320 Jenn Air Cooktop with down draft. I need a burner switch and a fan switch.
Oct 03, 2009 | Jenn-Air JED8230 Electric Cooktop
I'M LOOKING AT A USED COOKTOP BY JENNAIRE MODEL #JEC 8536ADW SERIAL #10672300CC. HOW CAN I FIND OUT HOW OLD IT IS. IT LOOKS ALMOST NEW
How old is my appliance?
Brand: Jenn Air
Type:
Country: USA
Model: JEC8536ADW
Serial: 10672300CC This product appears to have been manufactured February of 2003. (MAYTAG-10)
Sep 29, 2009 | Jenn-Air 35 in. JEC8536A Electric Cooktop
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Front double burner not working on Jenn Air ceramic cooktop model # JES8750AAB
tnx gerbee
Jun 29, 2009 | Jenn-Air JED8430 Electric Cooktop
1 cooktop light stays on 24/7 even when its cold.
one of the burner sensors is fused that burner must be replaced
Dec 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JED8230 Electric Cooktop Logo
176 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
