Question about Kenmore 53092 / 53094 Side by Side Refrigerator
The lever that you depress with a glass to get ice cubes is broke
I have tried several times to glue or epoxy the lever and it continues to break.
do you have a solution?
thank you
  • 3,037 Answers
You could just replace the lever. repairclinic.com should have the lever. Just put in your model number and search. You can also try appliancepartspros.com
If you want to try fixing it again, May I say that you may want to put some other kind of piece on the back side of the lever and glue that piece onto both parts of the lever to keep it from breaking.
Benjamin
Posted on May 29, 2010
How do I reattach an otherwise intact passenger side mirror on a 2002 chrysler 300m?
if its just the glass that has come off you can have it re-glued at a glass shop. or you can try a glass epoxy glue and try it your self and hope the mirror won`t fall off and break.
Sep 11, 2014 | 2002 Chrysler 300M
Ice cube dispenser
make sure the ice maker lever is in the down position, when removing the tray the arm was probably moved to the top(off) position as if the tray was actually full which would shut off the ice making process
Aug 30, 2012 | LG LFX25971ST Bottom Freezer French Door...
Ice dispenser will only give crushed ice; will not dispense cube ice ;I have looked at the auger and chute and nothing wrong there; when I chose cube, it dispenses crushed in both the crushed and cube...
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
Sep 07, 2009 | Kenmore Refrigerators
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
May 27, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice Make will not Dump into Bucket
The arm that drives the ice out of the freezer tray is driven by a small motor in the front of the ice maker. The motor has a small gear that drives the larger gear keyed to the front of this arm. If the ice is ever allowed to thaw and re-freeze the driven gear can break one or more teeth off affecting the operation of the ice cube removal. None of the parts of the ice maker are available separately. However these parts are easily repaired with super glue or epoxy. When re-installing the drive arm it must be located with the drive fingers horizontal.
Feb 28, 2009 | GE Refrigerators
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Apr 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker
some part inside ice maker has broken. Attempt to pry off cover (or remove screws if necessary) and look for any part that has broken. I will guess the part is plastic. This same thing happened to my maker and I deduced that an item had fallen into the ice cube tray and prevented the arm from coming up, thereby allowing the tiny drive motor , coupled to a speed-reducing-torque-increasing mechanism to break a part of the maker. I actually used strong epoxy glue to fix it!
Jul 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
Icemaker doesn't work - no ice ejected
Krakus, there is no fuse in the dispenser assy., but there are two switches mounted on the control bracket. The posts on the brackets that hold the switches are really thin and it's possible that it broke. Therefore when you are pressing the lever you are not making the switch and sending the juice to the auger motor. Remove the dispenser cover by inserting a flat blade screw driver in the slots at the bottom. Pry out gently and the cover should pop off. Then slide it up and off. Now you will be looking at the control bracket and see the switches on the left and right side. See if the switch holder is broken. If this is the case your part number is 2183771. Not a hard job, just have to take your time. Im assuming that when you tested the auger motor you verified that the drive coupler was not broke. Catriver..post back
Dec 18, 2006 | KitchenAid KSCS25FKSS Side by Side...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
