Question about Kenmore 94802 Front Load Stacked Washer / Dryer
Kenmore 94802 washer belt overheats, smokes, and melts
The other day the washer motor belt on my Kemore 94802 Front Loader started smoking bad. I opened it up and found that the belt had not moved and sat there on the motor pulley and melted down. I replaced the belt thinking it was just worn. Everything worked great for about 5 minutes and then the new belt started to smoke. I think the motor might be getting a little too hot.
But I was also thinking that something may need to be lubed or greased, since the motor may be having to work hard because its getting overworked.
Any thoughts?
  • Anonymous Jan 06, 2009
    smokes spin cycle don't work effectively
    President:
  • Kenmore Master
  • 2,651 Answers
Sounds like perhaps the trannsmission has locked up and is not spinning freely, therfore the belt is meeting resistance and not turniing.( try turning the trans. pullley( where the bsck of belt is wound)does it turn freely??? try turning the tub from inside does it spin at all??? before i condemn the tranny i would check for article of clothing fallling between the tubs, holding from spinning, also ive seen (nails/screws/bra underwires,etc..) poke through onr of the holes with in the tub abd stuck to the outer tub also preventing the tub from spinning, look closely to all the inner basket holes!!!
Posted on Apr 08, 2008
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
Troubleshooting kenmore washer front loader 417 390 12890
basket rubbing to the door gasket ..could be bad bearing or broken spider
Mar 01, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer squealed, gave off black smoke in spin cycle
For sure change the belt. Clean the pulleys with a solvent to remove anything oily or like melted belt. The machine probably was overloaded. If it's a front loader, check the bearings.
Nov 24, 2013 | Washing Machines
Washer does not turn or spins
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Stacked kenmore tranny problem?
yep. belt started smoking because motor is turning and not the tranny.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
SMOKE
it may just be a wire rubbing the tub and the insulation is gone. smoke means something is not right. the drive motor will smoke if the windings overheat neccesitating a new motor. - the start or run capacitor for the motor may be bad.
Dec 27, 2007 | Washing Machines
Smoking Kenmore Washer
try www dot partselect dot com they have exploded diagrams on appliances.
Dec 10, 2007 | Washing Machines
Kenmore 94802 Front Load Stacked Washer / Dryer Logo
298 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
