Question about Bowflex Treadclimber
My machine is making a grinding sound (medal to medal) when i use the machine. if i lock it and only use treadmilll it is ok. it seams to happen more and more. i really grinds if i stand on step offs. don't know what happened it just started. bowflex treadclimber 5000
    President:
  • Bowflex Master
  • 832 Answers
You'll need inspect the movable areas of your unit by hand something may have come loose or see if their is any excessive lateral play could be worn or cracked bushings. Have some else help you by stepping off on either side to see where the sound more prominent. Unfortunately it a process of elimination good luck!
Posted on May 29, 2010
My CanonPC940 won't grab paper and push it through to print-also makes a a loud "grinding" noise. How can I fix this?
Sounds like a tire may have slid off of a wheel. Yes they have wheels. Also paper soaks up water like a sponge always keep your paper in the wrapper it comes in and the top side of the paper is where the seam is. Make sure you put the paper in so that the top side is the side going through the machine. I do how ever believe you have a wheel or gear out of place.
Oct 15, 2015 | Canon Office Equipment & Supplies
Front load washer will not spin
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FRT18HS6JS Stainless Steel Top...
Dodge stratus grinding noise in front ???
your rotors are wet they have to dry out
Nov 26, 2013 | Cars & Trucks
Nv500 brother machine maked a grinding sound and wont stitch it just gathers and knots can you sugest what it might be?
Something is bound up. Stop trying to sew. Turn off the machine.
Take off the foot, take out the needle, take off the bobbin cover, take of the needle/throat plate and check for the reason for your problem. Look for lint, threads caught up underneath and in between the parts.
Clear all that out and put it back together and attempt test seam.
Nov 19, 2012 | Sewing Machines
Hoover 2305l washing machine grinds and locks up
First remove the belt and spin the motor it may be motor bearings if this checks ok then the gears in your transmission are meshing which means you will have to fit a new transmission.
Aug 03, 2012 | GE Washing Machines
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
Keep spinning
sounds as if hte tub block has gone bad. its the locking block that ties the inner tub t the transmission shaft, after it strips out nothing stops free rotation of inner basket.
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Right rear is making a sound of medal scraping medal. I believe it maybe the wheel bearings.
If it's a scraping sound, when does it happen? If it's when you hit the brakes, then it's likely your rear brake pads/shoes are down to the metal and are scraping. This can happen when you're not hitting the brakes, however. Bad wheel bearings are usually a moaning/roaring sound that increases as road speed increases. Ditto that for differential bearings - if they go out, you usually get a roaring noise that increases the faster you go.
Aug 10, 2008 | Ford Explorer Cars & Trucks
Bowflex Treadclimber Logo
223 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
