Question about Jl Audio 500/1 Car Audio Amplifier
I have two subs and a amplifier but dont have rca jack on back of my radio so hooked it straight through rear speakers and there wired through amp it works but amp aint pushin anything how do i get it to push
  • 311 Answers
What do you mean by push
also tell me how toy have wired it
Posted on May 29, 2010
How to hook up car radio to an amp when radio does not have RCA Jacks
They make a type of Amplifier that uses high level input from the speaker outputs. Contact a company called Crutchfield.com for details and prices. You ca also have a radio shop install preamp output RCA jacks to the factory radio, do an Internet search for shops that do this type of retrofitting.
Apr 29, 2012 | Cars & Trucks
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
Instructions for the 500 watt amp
1/remove positive cable from battery.2/install rca jacks to rear of your radio/unit.3/find a suitable safe out of veiw area to mount amp with adequete ventilation [because it will get hot] .4/run and tuck your rca's agian outta site,never in a door jamb.5/also most install kits have a auto on/off wire that runs with the rca wires,that gets tied on to your power antennea wire on the stereos wire harness6/once you have rca,automatic on/off hooked,or near your amp ready to plug in.,you can then , cut as short as possible ,the ground wire[that should be black in color]the shorter the ground wire ,the less feed back you will get! under 14 inches is best .mount the ground very secure under a front seat, loosen a mounting bolt to the seat then wrench tight[making sure it is metal to metal,no paint can be in between contacts then run the power wire [red to red] straight to your battery positive cable [very securely] you should find a access point to push the wire thru the firewall someplace do not hook up the battery though finish runnin the power wire to amps destination after the amp is secure ,add power wire plug ins to amp then runn your speaker wires to box re-attach battery terminals [will be a small spark ] dont panic . upon turning on listen to your favorite song loud,so you can adjust the amplifier to yer liking
Mar 20, 2011 | Visonik Vpb210pk Complete Dual "10" 1,000...
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
ALL THE WIRES ARE RAN CORRECTLY,THE GROUND IS SECURE UNDER A BOLT UNDER THE SEAT,THE SUBS ARE HOOKED UP RIGHT,BUT THE PROTECTION LIGHT IS STILL ON
the protection is on because if any speaker has internal electric problems as open circuit or short circuit, need to be checked
Jan 03, 2010 | Boss C650 Car Audio Amplifier
How do you hook up a sub and amp to a stock radio with NO RCA outputs?
you can splice into the wires for your rear speakers and install some of your owns rca's and just use the low pass filter on your amplifier to eliminate the mids and highs from the frequency to your subs.
Jun 24, 2009 | Kenwood KSC-WD250 Car Subwoofer
Unwanted bass coming out of my subs
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Feb 24, 2009 | Kenwood eXcelon KAC-X812D Car Audio...
Amp connection
The only amp wires that connect to the Head Unit are:
Amplifier remote turn on wire to Blue/white at radio
and RCA audio cords to SUB or REAR output RCA jacks.
Aug 04, 2008 | Pioneer 50W x 4 MOSFET Apple iPod...
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
Jl Audio 500/1 Car Audio Amplifier Logo
54 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
