Question about HP Pavilion M703 17" CRT Monitor
I have an HP Pavilion m703 monitor which changes the screen shape to pincushion every time it is booted up or brought out of energy-saving mode. Naturally, I use the set-front menu to reset it but it never lasts. Any ideas?
viziks
  • 220 Answers
SOURCE: problem on hp monitor
The problem should be defective keypanel.Try replacing the switches .
It should solve your problem.
Please provide feedback and rate this solution.
Samir.
Posted on Apr 08, 2008
SOURCE: hp pavilion f1503 momitor
Hold the MENU button for 10 seconds to lock or unlock the OSD
Posted on Aug 19, 2008
leroyal
  • 2120 Answers
SOURCE: hp pavilion f1703 problem
Burned out backlight fluorescent backlight.
Posted on Jan 04, 2009
aliencountdo
  • 55 Answers
SOURCE: monitor goes into power saving mode
A monitor switches to power saving mode when it is not receiving a signal from the computer. Check the lead isnt loose & if you have removed it recently, check you havent bent any of the pins.
Posted on Sep 30, 2009
  • 12 Answers
SOURCE: I have a Problem with HP Pavilion F1703
Try connecting another screen and change resolution & frequency level to like 60hz, then switch back to your hp monitor.
Posted on Dec 22, 2009
I have a Dell Dimension e521 desktop that has gone into energy save mode after I ran Norton security check.. Pressing any key or clicking the mouse doesn't do anything. The screen is black and says...
you may find you have the screen resolution set to high, try changing to 1024x768 and try again. if this works it means your monitor ain't up to the job of your better machines.
Nov 15, 2013 | Cars & Trucks
My HP Pavilion 1903 monitor keeps going to sleep every time I turn it on
check in your monitor menu to ensure there is no energy save mode set. press the menu button on your monitor and check the settings. ensure that your pc also does not have an energy save setting set. e.g if the mouse or keyboard are not touched for a specific time e.g. 1 minute then switch off monitor to save power. make sure that such settings are not switched to on in your pc settings. if this is a new monitor and this was not a problem with your old monitor then suspect the monitor settings if the monitor and pc are both new. then suspect both settings. if possible test the monitor on a second pc or laptop to see if problem persists.
Dec 11, 2010 | Computers & Internet
Just replaced power supply unit from a 250 watt to a 480 watt and now computer comes on but will go into power saving mode instead of booting up and keyboard doesn't stay lit like it used to.The system is...
Which power supply went bad? The 250watt or the 480watt? If a power-supply goes bad (dies), it generally takes some (if not all) hardware with it.
Jan 05, 2010 | HP Computers & Internet
Power saver mode problem.
Reset the Memory cards.
And if you have video card reset the video card as well.
and it will work fine and even if it does the same issue your memory or Video card needs to be replaced.
Oct 24, 2009 | HP Computers & Internet
No display
Try your monitor by itself just power it on and nothing else hooked up to it, you should at least be able to see some diagnostic screen if the monitor still works. If not its probably dead.
Sep 10, 2009 | HP Pavilion M703 17" CRT Monitor
What is energy saving mode on a HP and how do I turn it off
enter the bios and under power management change the settings from power fauilure return to last last to boot
Dec 19, 2008 | HP Pavilion a450n PC Desktop
My screen acts as if it's on energy-saving-mode but doesnt activate...
Check and reset the Screen Saver to the settings you want, even if its set properly. Did this work?
If not, reset the monitor to factory defaults to flush its memory.
If that doesn't work unplug the monitor for a minute and replug.
Sep 02, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Monitor
Boot up using safe mode, then check the display properties for the Energy Monitor Power settings under the Screen Saver tab.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | Computers & Internet
HP Pavilion M703 17" CRT Monitor Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
