Question about Pioneer GM-X334 Car Audio Amplifier
What is the easiest way to install a gm-x334 amp
I don't know how to do it. I don't want to pull the radio out. Can I just tap into the rear speaker lines and hook the amp up to the battery in the rear of car?
  • 311 Answers
Yeah thats fine
but to be honest it would be better to look in the back of the radio for rca jacks
but you can tap into the rear speakers wires
also connect the negative of the amp to a metal point on the car, not the negative of the battery
and the positive of the amp to the positive of the
battery
also you need to find a remote wire (this is usually behind the radio)
so im guessing you will have to take out the radio
unless you add a switch from the postive of the battery to the remote jack of the amp
and manually turn on and off the amp while driving the car
but this runs the risk of leaving the amp on and draining the battery
so i suggest taking out the radio and using the wires behind it
Posted on May 29, 2010
Testimonial: "Very good thank you!"
Anyone have a 2012 Chevy Silverado radio wire diagram so I can install my subwoofers to a factory radio?
The factory radio does not offer RCA outputs. The easiest thing would be to tap into the rear speaker wires at the point where they go up the C pillars.
Aug 02, 2017 | Cars & Trucks
Why are my speakers of my Monsoon radio making noise when ignition key is off?
Depending on the year of the car. The factory amp may be wearing out and need to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/nathaniel_9ed79ef078a2f164
Aug 05, 2014 | Pontiac G6 Cars & Trucks
How much does the amp go for new
Hello
The car amplifier you specifies here 'Pioneer GM-X334" will cost about $105 for new one. You can buy it for $60 if it is a used one and in good condition. OK.
Dec 18, 2011 | Pioneer GM-X334 Car Audio Amplifier
I have a pioneer gm x334 car amplifier and the power light keeps flashing instead of staying steady. what does that mean?
make sure remote wire is good and tight, also make sure the ground has a solid connection.
If this helps please leave me a rating, thanks.
Jul 07, 2011 | Pioneer GM-X334 Car Audio Amplifier
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
I need to know the stereo wiring for a 1998 ford windstar. im trying to put in a new and i dont know what wires to match it up with
here you go...
1998 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
Oct 16, 2010 | 1998 Ford Windstar
Pilot light on unit is flashing rapidly, no apparent output
disconnnect speaker wires , if amps light is steady then its one of the speakers or wireing . if not check ground ,or use a meter to check rca barrel to amp for ground set meter @ rx1 ,see amps ground is solid and clean
Nov 07, 2009 | Pioneer GM-X334 Car Audio Amplifier
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Apr 29, 2009 | Car Audio & Video
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Sep 29, 2008 | 1996 Ford Explorer
Installation
Buy an amp wiring kit. The battery cable goes to the battery (duh, right?) with the fuse within 18 inches of the battery. The ground gets bolted to a clean section of the car chassis/body. the remote lead goes to the radio's remote out (blue/white stripe). the rca cable goes to the radio's Sub/rear RCA outputs. Speaker wires go the speakers. Done!
Sep 12, 2007 | Pioneer GM-7300M Car Audio Amplifier
Pioneer GM-X334 Car Audio Amplifier Logo
207 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
