Question about Yamaha RX-V663 Receiver
Is there a code so I can connect my Pioneer PD F505 to my Yamaha RX V665?
  • carlw259 Jun 03, 2010
    Perhaps I wasn't clear. The Yamaha remote for the RX V665 claims to be able to operate TV, DVD, & CD hardware, and lists 2 pages of codes to program the remote for other brands. My question is "what is the code for the Pioneer PD F505 cd 25-disc changer? There is no optical digital cable connection, but there is a single hard-wire that worked when I had the Pioneer receiver. It plugs into the Yamaha exactly the same way.
    Brigadier General:
  • 8,546 Answers
What do you mean - code? It's hardware, connect it via its optical digital cable.
Posted on May 29, 2010
Testimonial: "This is very helpful. Thank you."
  • David Dunn
    David Dunn Jun 03, 2010
    Wired interconnects like you used to use with two Pioneer"SR"-compatible products are probably proprietary. I'd avoid plugging 'strange' control cables from one manufacturer's product into another without explicit recommendation to do so. Physical fit alone does not guarantee electrical compatibility and could blow something up.
    Yamaha (and others) don't make it easy to figure out the remote codes for other manuafacturers's products. For example, under Yamaha's list for Pioneer TV's there are 14 codes, but under the CD category it only mentions one code for Yamaha CD players only.
    That your Pioneer is a disc-changer instead of a single-disc player would almost certainly mean it has commands on its own native remote that wouldn't appear on a 'universal' one. Even if you could get the Yamaha remote to do certain things like Play and Pause I doubt it would have controls for disc selection and higher functions like programming.
    Universal remotes are good for basic functions but rarely would have special-purpose buttons for unique functions. My own preference is to use the supplied remote for each of my highly-specialized products to avoid loss of certain controls or mistaken command interpretation by the wrong device.
How to code yamaha rx-v665 into directv remote
Go to the Directv Remote programming Page and enter your device
It will give you the correct codes or a universal code for your brand receiver.
Oct 02, 2014 | Yamaha RX-V663 Receiver
My pioneer pd f505 is lock how can i unlocked it
The loading mechanism is out of alignment and needs to be fixed before the door will operate correctly.
Feb 26, 2013 | Pioneer PD-F505 CD Player
RX-V665 turns on for a second then turns off
don`t open it yet
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 13, 2012 | Yamaha RX-V665 Receiver
Need a manual
Simple web searches get answers faster than waiting for one of us to pick up the question.
Try "Yamaha RX-V665 manual"
Aug 03, 2011 | Yamaha RX-V665 Receiver
I have a Yamaha RX V665 and I am unable to change the volume
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jun 07, 2010 | Yamaha RX-V663 Receiver
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
Apr 17, 2010 | Yamaha RX-V663 Receiver
I need a manual
Hiya,
Here is the manual:
PD-F505 Manual
You will need to rate this CD player (put stars in 4 star area's) before it lets you download.
I have downloaded the file, it is clean and it is the correct manual for your CD player.
Regards
Mike
Mar 24, 2010 | Pioneer PD-F505 CD Player
How do i connect my cable tv to my yamaha rx-v665? i do not have a cable box
If your tv has an audio out jack attach a rca cable from that to your receiver any audio input.
Dec 19, 2009 | Yamaha RX-V663 Receiver
Pioneer PD-F505 lower CD door closer spring has sprung LOOSE!
use krazy glue to get the arm glued with the cd port or use electrical tape.
Jul 14, 2009 | Pioneer PD-F507 25-Disc CD Changer
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
Yamaha RX-V663 Receiver Logo
349 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
