Color is Messed up
Philip's 65" HD TV , the color is messed up, it looks 3D
  • 121 Answers
You need to replace your convergence ic's give me your model number and I'll be able to tell you what ic's you need and a link to where you can buy them and get free installation instructions and free online support so you can do the repairs yourself
Posted on Apr 12, 2008
SOURCE:
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
Color is messed up...very green looking screen, appears red colors appear green
Do you have extra hardware connected to the TV? If so, it could be a problem with the cable/connections.
Mar 07, 2011 | Proview Hx263 26 in. HD-Ready LCD...
The color is extremly messed up...peoples skin is redish and the green is like a neon color? How do I adjust the color frm the back of the tv?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 05, 2011 | Philips Magnavox 9P6034C 60" Rear...
My hitachi rear projection tv has one of it's colors out of alignment almost like it's been bent because it causes the blue color to be out of alignment in a curved fashion across the screen the tv worked...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 02, 2011 | Hitachi 50FX20B 50" Rear Projection...
AV-36D800 - Color is messed up. I have tv sitting
Yes it could very well do it. Could you rotate the TV or the safe? Or better still, place the TV on a wooden table.
Aug 28, 2010 | JVC Televison & Video
Have a westinghouse HD lcd tv about 2 years old, about 2 weeks ago the color messed up cant get it back, the color is missing reds and its weird just the color is screwy cant seem to get it rigth, hit the...
Usually a color missing is a bent pin if you are using it as a PC monitor. Definately check your cables and see if the problems follows the input selections. If it does it most likely is a electronic component failure. Of course this assumes the settings aren't randomly messed up. You might be wanting to invite that guy that always has things taken apart when you visit...or start watching online sales...head's up on repair bills...a similar product costs $400 new, 300 refurbished.
Aug 26, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Color convergence is off
Please chech degausing coil around crt from inside
Jun 13, 2009 | Televison & Video
RCA HD 61w66 color is messed up...
problems like that is caused by moisture inside the unit.sometimes it goes back, like nothings happened.but, if not a tech is the only option.
May 20, 2009 | Televison & Video
Looks 3D
I had a repairman replace the convergence boards. The picture is fine now however red & green colors are messed up.
Nov 11, 2008 | Samsung HCN653W 65" Rear Projection...
3D images
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Ekse
