I have a freeview build into my tv which is Panasonic plasms tv Model no. TH-46PZ8BA and wish to know how I can receive HD channels BBC or ITV. Please advice and help.
    Brigadier General:
  • 3,006 Answers
HD Ready just means the tv can display HD images from an HD source.
The built-in Freeview box on your tv is not Freeview HD compatible so you'll either have to buy a separate external Freeview HD box or subscribe to an HD satellite or cable service.
In any case, most built in Freeview receivers are of barely adequate picture and reception quality. An external box is usually far better in both respects.
Posted on May 29, 2010
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
Hi have a built in freeview alba tv tune in channels working fine but dont have any bbc or c4 c5 any one can help me or send tv back
Can't tune Alba LCDW16HDF :( - Freeview - Digital Spy Forums
forums.digitalspy.co.uk/showthread.php?t=1238173
Digital Spy
Apr 1, 2010 - 17 posts - ‎8 authors
No matter what the problem DS Forum posters will always provide an answer ... That the Alba is your only digital television receiver - you don't have another ... I suspect the set may have found Craigkelly's BBC & ITV/C4/C5 ... BBC Three questions? - Broadcasting
Dec 13, 2015
Why dont RTE do this - Page 2 - Broadcasting
Aug 21, 2015
Channel 4 Licence Renewal and Scotland - Broadcasting
Mar 12, 2014
Why Won't Freesat/BBC let Viewers Nationwide have ...
Jan 20, 2014
More results from forums.digitalspy.co.uk
Freeview Help: Missing Freeview Channels - Radio and Telly
Jan 01, 2016 | Alba Televison & Video
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
How do I receive itv player and bbc iplayer on my Bush freeview + model b1 tb hd pvr
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Dec 03, 2013 | Bush Televison & Video
I have an LCD HDTV BLA. I have Freeview and
Hi.
If you are using an external freeview box you need an HD box (See available products).
If you have an LCD TV with built-in HD tuner (TV will say HD Ready and will have internal tuner), then you can use the TV internal tuner.
The best way to get HD is via satellite. Althought HD Freeview is theoretically available since end 2009 I have not been able to receive any HD channel using Freeview tuner, and I live in a London area where HD FV is supposed to be available since 2010.
Even with Free Sat the choice is poor. You get steadily only BBC HD, where at most you can watch some documentary or drama series (it is a kind of sample channel). ITV HD, BBC1 HD and the rest frequencies on Astra change Sat quite often. I am a TV technician and the sat tuning job is not difficult to me but retuning every month was still an awful waste of time.At the end I gave up and I only watch HD through Sky.
At the end of the day the only efficient way to receive HD TV is still through Virgin or Sky.
Regards.
Ginko
Sep 01, 2011 | Samsung Televison & Video
Auto set up finds only some of available programmes. Only ITV channel found is ITV 4. cHANNELS 4 AND 5 not found. Very good reception on programmes it has found. Full range of programmes viewable...
It maybe that the TV needs to be completely reset. in the menu somewhere should be a setting to "restore factory settings" or "reset to default" something like that...
Try this and post the results...
Aug 27, 2010 | Panasonic (TH-50PZ700U) Television
I have retuned my Panasonic HD TV as per your instruction which I printed out. Fine with ITV, Channel 5 and 5. BUT BBC 1 AND BBC 2 are fuzzy. Can you help please?
both of those channels are in anolog, so on todays tvs they are going to look that way, sorry , something you have to live with if the cable company puts them on a digital channel they will look better but not HD quality
Sep 30, 2009 | Panasonic Televison & Video
Satellite works fine in the day but no signal in
I have run into this problem a couple of times, once a loose connection at the LNB, other times it has been due to moisture build up (dew) in the loose connections, check all connections from the LNB through the tuner, and any other devices involved (a line map maybe?) that will most likely resolve the problem.
Sep 15, 2009 | Televison & Video
Lost ITV channels and C4
I've got exaclty the same problem :-/
HELP!
Oct 06, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
