Question about Electrolux 30" Built-In Double Electric Convection Wall Oven - Stainless-Steel
Door does not shut completely - Electrolux 30" Built-In Double Electric Convection Wall Oven - Stainless-Steel
    Sergeant:
  • 228 Answers
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
Posted on May 29, 2010
Can I get a replacement for the lower oven door of an Electrolux EDC6935 wall oven?
Hi Mike - I am happy to assist you. First, according to my research, the model number that you have provided me is appearing invalid according to the Electrolux database within the US. Are you located outside of the US? Generally speaking, for some units the complete door set would need to be replaced. However, may I please have the correct model number, to better address the issue at hand? Typically the serial tag is located in the storage drawer on the right side. Thank you and I look forward to your response.
Jun 18, 2013 | Electrolux Ovens
I am getting a E1 F5 error on the oven - what is the cause?
E1 F5 error is indicate that door latch is not working
This may display if the door is not shut properly, if it is jammed or if the spring-loaded mechanism has broken. Make sure door is completely closed and switch is closed. Test latch, solenoid and actuation switch (require an ohm meter to test).
Considerations: Try opening the oven door and shutting it while putting pressure on the center of the switch until you hear a click. Jiggle the latch to try and reposition it so that it shuts properly. Examine the latch to make sure it is properly attached.
Prevention/Solution: If none of those methods remove the error, you may need to replace the door latch. Visit the Whirlpool customer service website to find the correct part you need.
Hope this helps.
Jun 02, 2011 | Ovens
Door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
Feb 28, 2011 | Viking Ovens
Oven door won't completely shut
either the hinge screws are lose or the door is sprung! and needs to be readjusted
Jan 20, 2010 | Ovens
My oven door doesn't close completely. Is there a way to adjust the door?
Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
Stove is brand new. turned oven on for 30 minutes for initial burn, open door, but it won't shut completly, why?
You don't provide a make or model number, but if it's new, look in the Owner Manual for door malfunctions. Call the store where you bought it and tell them of the problem.
Dec 18, 2009 | Ovens
Door won't shut completly, maybe new hinge needed
If it is a drop down door, then, yes, the only solution is to fit a new pair of hinges.
This will undoubtably solve the problem.
Dec 16, 2009 | Ovens
Electrolux 30" Built-In Double Electric Convection Wall Oven - Stainless-Steel Logo
587 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
