Question about SAMTRON 55V 15" CRT Monitor
My monitor resolution colour is changed to pink.
How to put it into normal
    Brigadier General:
  • 10,406 Answers
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
Posted on May 29, 2010
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
Monitor will come on briefly then turn back off, what could be the problem?
A distinct possibility would be a resolution error in the operating system. Try booting in "Safe Mode" (I assume you use Windows), and see if it works. If it does, change the resolution to something safe, such as 1024 x 768 by 16 million colours (24 bit), or even lower. Then boot normally. At that point, increase gradually the resolution.
Jun 17, 2010 | Advueu Technology ADV178T 17" Flat Panel...
My Acer AL1716W monitor flickers, but only when I'm on the internet.
flickering monitors normally mean the lamp is on its way out but this sounds like your PC has issues either with the graphics card or memory. Run a virus check and antispyware software. If you don't have this software try microsoft security essentials its free. and people tell me its good.
Also try changing graphics card settings like resolution and refresh rate changes it might have something to do with colour schemes. Update graphics card drivers and I recently had a similar issue and had to upgrade the graphics card to handle the resolution of my monitor
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
My monitor changes colors (e.g. normal then turns
Color changes on the display mostly occurs because of a faulty VGA cable or a loose connection of the cable to the VGA port at the back of your PC or Monitor. But if the cable is fixed securely at the back and the problem still persists, slightly move the cable's wire segment while observing its reaction on your monitor. Does it change colors while u do so? If it does even when the cable is securely plugged in to both the PC and the monitor, then u need to change the cable.
As for the visible display area size (technically called the Resolution) right click on an icon free area on the desktop and click Properties. At the top of the form click on the Settings tab. At the bottom of this form find Screen Resolution and adjust it to it your requirements and click Apply. On the confirmation dialogue that pops up click Yes if the displayed resolution suits u otherwise click No and try another resolution size. Hope this helps.
Nov 28, 2009 | AOC CT720G 17" CRT Monitor
My monitor colour gone pink tried all I could but no change is there any problem in my cpu
no theres no problem with your cpu, its the monitor that has a problem, have your monitor check by a qualified monitor tech., if the color changes to pink theres a problem inside, dont do anything that you are not sure of doing, you can try to plug another monitor if you have doubts
Nov 24, 2009 | AOC CT720G 17" CRT Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Colour blending problems.
Try updating your video card drivers as well as your monitor drivers and see if all the resolutions work at that point. If they work then everything is good to go, if it doesn't work then try another working monitor and if you still have the color blending problems then the video card is faulty.
May 04, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Colour fade of my 793s
rainbow colour is normally due to magenatic effect on monitor
see that any magnetic thing is near monitor
 if it is there remove it
.after that put off monitor for 15 minutes & then put on.see if any change is there
 if there is any change is there wait for 2 or 3 days it will be ok.
if brightness is also less along with fad color then
 check for video output section & crt electrodes for normal voltage.
it that is also ok then crt is getting weak,
please be in touch with me unless it is solved.
hope this will help.
Oct 11, 2007 | Samsung 793S 17" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
216 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
Richard Lilja
Richard Lilja
Ted Maxwell
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
