Try hp usb format tool. You can download it at http://www.pcworld.com/downloads/file/fid,64963-order,4/description.html
First Option:
Explore your USB drive using Nero 6.0 Burning ROM Software.. This shows all hidden files in USB Drive.. Try to delete all files manually through nero 6.0 itself. if you fails, USB is Damaged.
Open your USB Drive in Linux OS.. (Fedora 9.0 and Above is most recommended).. Delete all files manually.. thats all
SOURCE: write protected
First try to see is there any lock in your usb pen drive and see if its
not locking the pen drive, because some pen drives comes with that
option to protect usb .it looks like slide switch .for one end it will
lock the media and when you switch to other side you have the full
access
but if that's not the reason it might be the problem with registry
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low
feed backs hurt my ratings and I tried my level best to resolve the
issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
option to protect usb ..if its not
Low
