Question about Barco SLM R10 Multimedia Projector
Cannot seem to be able to factory reset... Menus are not available
No display or picture. has sound.
try resetting to factory default through the menus available from the remote control. The option should be in the general or settings menus. This may clear the fault. Check your antenna/aeria is working and correctly connected. If this produces no remedy it is possible that the sound output of your televisions motherboard has developed a fault or there may be an issue with the speakers or their connections to the motherboard.
Jun 13, 2015 | Vizio Eco VO320E 32-inch Class Television...
Can it be reset to original as new out of the box.I made a mistake in the set up and although it works it is not as it should be.I need to add I am in my early 70s and I am not to hot on tech.terms.
Hello Douglas, I am not far off my sixties so this will be a very
general description of the procedure that will require you to do some checking yourself.
There will be a number of menus available to you when you press the menu buttons on the remote control.
Look for the general and settings menus rather than those relating to tuning/audio/video etc..
You should carefully search through the settings and general menus until you find something like 'factory reset' or 'reset to factory default'
You simply need to highlight the option and then press the button to reset.....you willl [psson;y be asked to ok the procedure. It is very straightforward and should not take very long to carry out
Good Luck
Jun 11, 2015 | LG LED 22CV241-B Chromebase 22INCH...
Display only shows half lines. How do I fix this?
Hi, it may be possible to restore the set to factory default through the menus on the remote control, the option should be available through the settings/ general menus. If you are able to reset then perform an autosearch. If the reset achieves nothing it is probably time to call in a technician. Possibly some of the capacitors/condensors have blown. It is difficult to diagnose from a distance. Don't think it has anything to do with aerial/antenna.
CRTs are not built modularly so it will probably need a repair that involves parts possibly being soldered in.
Good Luck
Jun 11, 2015 | Televison & Video
Mitsu 60735 picture comes on then shuts to blinking red light
Hi Edward, not really an expert on these but , if it stays on long enough, I would attempt to reset it to factory default through the settings menus available through the remote control. I consider that if a reset cannot correct cranky behaviour then there is something wrong that requires the services of a technician.
Good Luck
May 29, 2015 | Televison & Video
How can i reset factory setting on my sony dsc55 camera
Reset button on the camera
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Initialize or Reset option(s) in the camera menus
  • The menu layout is different between cameras so check the operating instructions.
  • In general, there will be a Reset or Initialize section within the menus of the camera.
  • Some cameras allow for resetting or initializing different options such as wireless settings, the settings used in taking the last picture, or all settings. Be sure to look at all available options in the product manual.
Manual reset process
Cameras manufactured prior to the year 2000 do not have reset buttons or options in the menus. Follow the steps below to reset:
    1. Turn off the camera.
    2. Remove the battery pack.
    3. Remove the button-sized lithium battery.
    4. Allow the camera to remain without power for 30 seconds.
    5. Reinsert the button-sized lithium battery.
    6. Reinsert the battery pack.
    7. Turn on the camera.
NOTE: If your camera is experiencing an issue and it is not resolved by performing the appropriate reset or initialize procedure above, service may be required.
Jan 06, 2015 | Sony Cyber-shot DSC-W55 Digital Camera
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
How to reset factory settings for samsung finesse
Did you already ask for the code to unlock the person who sold you the phone on ebay? It seems to me that this would be the logical thing to do?
Aug 28, 2012 | Samsung Finesse SCHr810 Cell Phone
Mitsubishi WS 55805 nothing but blue screen and black square in middle
A full service manual is available online---I will presume you tried to unplug it for a while and then power back to see if will reset itself.
This set has three hidden menus---one is the OPTION menu--in that menu with the Mitsubishi remote you can do a hard reset of the entire set= sets all back to factory except convergence adjustments which are stored in another area--cures all kinds of oddball issues.
I can give you a link to the manual and the page numbers for the OPTION menu.
Note: the other two hidden menus are Convergence and adjustment--do not go into adjustment menu as one wrong move and poof!
SD TECH
Apr 20, 2012 | Mitsubishi WS-55805 55" Rear Projection...
When I take outdoor pictures they are all whited out. I can still take indoor pictures and they seem to turn out okay.
Sometimes the internal settings can affect this.
Go to the menus.
Then find a setting which is something like:
Return to factory settings or,
Reset all to Default or,
Many of these point and shoot Canons have settings:
func. set: Make sure it is not set to some setting for inside, florescent, etc.These will affect the bright settings.
Also, if there is no reset for default factory settings, then go through all the menus, including the ones in the Func. Set. -- Usually in the "joy-stick" center.
Jul 10, 2011 | Canon PowerShot A430 Digital Camera
How do I reset my flatron w2052tq monitor to factory settings? . I shipped my monitor to my new home and now I can't get my monitor and printer to agree on a color--I use a ColorMunki to calibrate,...
For the LG w2052tq, you can do a reset to factory settings through the OSD menu. Press Menu then go down to Setup. Press Auto/Set and go down to Factory Reset. Press Auto/Set and confirm the action. Then press Menu twice if needed to exist the menus.
Alternatively, press the Up and Down arrows together.
Remember that you can only adjust the white balance of the monitor when the incoming signal is Analog. Documentation for the monitor is available here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W2052TQ-TF&matchedModelCode=1000004018&searchEngineModelCode=W2052TQ&initialTab=documents&targetPage=support-product-profile .
I hope this helps.
Jun 24, 2011 | Computers & Internet
Barco SLM R10 Multimedia Projector Logo
19 people viewed this question
Top Barco Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
