Question about Home
I have a Kohler BubbleMassage K-1122-G Bathtub. I want to detach the blower motor from the tub and place it 5 ft. from the tub. Kohler seems to have the wire to lengthen the electric but has nothing to extend the air tub to the tub. What can I do?
  • cbmaple May 30, 2010
    The directions received were good but I need more specific instructions. I have not bought the tub yet therefore need more pictures or instruction besides cutting.
  • cbmaple May 31, 2010
    All comments are helpful but I still need to know how to connect motor when it is placed outside the tub area. Wiring is understood but I don't know how the air tube is connected.
  • 767 Answers
Hello, if the electric is long enough you will have to find some bulk tubing from the hardware store and a coupling then you can couple the tubes together and move the bubbler where you want it.
Posted on May 31, 2010
    What do you mean by bulk tubing. What is it made of. Is it rubber, plastic or what? Is it flexible, stiff or what?
  • Heath Moyer May 31, 2010
    You should be able to cut the tube and use couplings from the hardware store and new tube to extend the existing tube.
  • 857 Answers
Blower Motor Removal & Installation
1. Disconnect the battery ground. 2. Disconnect the blower motor wiring at the blower. 3. Disconnect the cooling tube at the blower. 4. Remove the 4 mounting screws and pull the motor from the housing.
To Install
5. Remove the clamp from the blower case and remove the blower cage. Mount the cage on the replacement motor. 6. Install the blower motor and tighten the 4 mounting screws. 7. Connect the cooling tube and wiring hardness. 8. Connect the negative battery cable. Check the blower motor for proper operation. 9. Cement the cooling tube on the nipple at the housing using Liquid Butyl Sealer.
Posted on May 30, 2010
  • Jayant Jha May 31, 2010
    Go through this it should help you :
    Kohler Archer K-1122-G-0 White BubbleMassage 5' Bath Tub with Comfort Depth Design
    Archer™ BubbleMassage™ 5' bath with Comfort Depth™ design
    The Archer BubbleMassage bath features Comfort Depth design, a deep soaking experience with a low step-over height. This exclusive design offers a relaxing bath experience that is easy to enter and exit. Water depth is raised to the same level as a standard 20" - 21" tall bath through the unique slotted overflow. The transitional aesthetic of the Archer Suite also complements many different bathroom decors.
    5' length
    19" height
    Slotted overflow raises water depth for a deeper soak
    120 precisely positioned airjets
    Armrests and lumbar support
    Textured bottom surface
    Features of the Kohler Archer K-1122-G-0 White BubbleMassage 5' Bath Tub with Comfort Depth Design:
    Acrylic
    1 hp blower motor with 300 W heater, and electronic user control
    Blower motor is supplied with a grounding-type plug-in cord
    120 BubbleMassage™ airjets
    Drop-in
    Slotted overflow for maximum bathing depth
    Low threshold height
    Integral lumbar support
    Armrests
    60° (152.4 cm) x 32" (81.3 cm) x 19" (48.3 cm)
    Brigadier General:
  • 4,090 Answers
Cut the blower hose in the middle and extend it using PVC pipe and some hose clips to secure the blwer hose to the PVC.
Thanks for using FIXYA
Posted on May 29, 2010
What is the best and safest way to remove the bacteria flakes from a Kohler Purist BubbleMassage Air jet tub?
http://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1198327_2.pdf
Call 1-800-4KOHLER 1-800-456-4537)
some parts are under warranty,call them b4 you do anything,they will help figure it out,the link is your manual
May 31, 2015 | Kohler K-1110-G-96 Purist BubbleMassage...
One clawfoot leg on my bathtub has slipped out of it's track...twice and caused the tub to fall twice. What might be the problem?
If you look under the tub you will notice there is a bolt designed to be tightened once the tub is leveled and in the correct position (at least that is how ours is made and it is an original antique). Anyway, try tightening up on this bolt or screw once the foot is in the correct position and this should solve the problem.
May 21, 2010 | Kohler - Bathtub - Clawfoot - Iron Works...
My jacuzzi works fine but the air button seems faulty as turning it makes no difference. The clear tube is connected to the box on top of the motor. Any thoughts?
Lots ot time a small spider nests in the tube or switch body. If you can detach the tube at the switch and run a pipe cleaner down to clear the web, that might help. also look for cracks or holes in the tubing.
May 01, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Where can I find the directions on how to clean my new jetted royal bathtub?
Here is a place you can go, the link is to Kohler however it dont really matter what brand you may have. The link will take you to the cleaning of an Acrylic Jetted Tub and there is also a link once there how to flush out your jetted tub and how often it should be done. Please give a 4 THUMBS UP if this free answer was helpful in any way. Good Luck and have a nice day.
www.us.kohler.com/tech/careandcleaning/wb_acrylic.jsp
Apr 01, 2010 | Home
I can't get the drain plug off from it's base. It's supposed to be able to unscrew, it just spins. It's a Kohler tub. Does anyone have a clue?
Is it a lever handle drain or lift and twist lift and twist there is a small set screw on the popup you need to look for it on the stopper post only loosen it until you can pull off stopper or screw will fall in the drain
Nov 09, 2009 | Kohler 1257-GLA-0 Mariposa 6'...
Motor not working at all. Won't even go on
a good electrican will check for power but may not be able to test a printed control board. Maybe simpler to get a spa repairman
Aug 12, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Feb 22, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
New bathtub chipped
You should ask a lawyer for advice on who should fix it, but there are kits available to patch chips like those. You apply it as a liquid and then wet sand it. They are fairly easy to apply, and inexpensive.
Dec 22, 2008 | Kohler Archer 5ft Whirlpool with Comfort...
Home Logo
70 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
