Question about Sony STR-DB940 Receiver
Rear speakers L and R not working and MD in and out not working on my Sony STR-DB940
    Brigadier General:
  • 8,546 Answers
I'm guessing these are separate issues.
Has either one ever worked and stopped suddenly?
From the manual:
"No sound or only a very low level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see page 33-35).
>>> Adjust the speaker volume (see page 72).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 20)."
Be advised that using any Tape Monitor loop (that's what the MD/DAT is) disables any digital sources. Not that that would explain the rear speaker failure. Analog sources can still be processed into various surround modes.
Any Tape Monitor use requires at least a live INPUT to hear anything.
Posted on May 29, 2010
Testimonial: "I have steel problem with thr rear sppakrs."
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya
www.fixya.com > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ...
www.badcaps.net > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
Sony str-de945 s.1 rear speakers not working
rear speakers may only work once you have a 5.1 or DTS signal source connected
Apr 20, 2014 | Sony STR-DE945 Receiver
if its a 5.1 channel home theater,it means you have to hook up the subwoofer or maybe a center speaker to its terminal to have them all working. 2 front speaker,2 rear speaker and 1 center speaker or subwoofer =5 and amplifier is 1 so it is a 5.1 channel.hope this help..
May 31, 2010 | Sony STR-DB940 Receiver
I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Jan 01, 2010 | Sony STR-DE845 Receiver
Is it possible to setup lip-sync on the DB940?
no adjustments in that unit for timing
Nov 02, 2009 | Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Speaker Impedance Question
Whats the rating on the Plasma? How many watts at 4 ohms? If the plasma is rated 100 w at 8 ohm... hanging a 3.4 ohm load would put a lot of strain on the plasma's output amp. At 3.4 ohm the amp would be trying to delive close to 200 watts at full power. But it depends on how hot you normally run the volumn. Remember an amplifier output is AC volts. 1 ohm of resistance is close to a dead short. The amplifier would have to work its *** off to supply that type of power and would probably burn the output op-amps. If the outputs burn & it pumps any DC current through the speaker wire..the speakers would be toast...if not catch on fire. Try to keep the speaker load at or very cloe to the plasma's output load rating. Also if the plasma doesn't state it will handle loads down to 2 ohms...It probably won't.
Gene
Mar 02, 2009 | Sony STR-DB940 Receiver
Sony str-db940
Most likely a cold solder joint somewhere in the audio circuit. Most likely on the legs of the relay that turns the speakers on or off. Also check the connections at the audio outputs. Give it a good look over for bad solder connections, given the symptoms that's 98% likely to be the problem.
Oct 06, 2008 | Sony STR-DB940 Receiver
Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
May 27, 2008 | Sony STR-DB940 Receiver
Rear speakers not working
  • Try this on your rceiver to see if it corrects your problem .If not make sure rear speakers are activated and properly connected
  • Sound Field Clear Mode
    The preset sound field is cleared when this mode is activated. Use
    this mode before returning the product to clients upon completion
    of repair.
    Procedure:
    1. While depressing the [MODE +] button, press the power `/1
    button to turn on the main power. The message S.F Initialize
    appears and initialization is performed.
Dec 05, 2007 | Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Logo
260 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
