Question about Husqvarna Chain Saw 20" Bar
Module-Ignition Husqvarna 444 Prufrex CE/90 not sale. Whether there is any analogue? Best regards. Vladimir
3 Suggested Answers
  • 211 Answers
SOURCE: Finding a ignition module for a Husky 444 SE 441 014634
hi
first check the wires,the cable from the coil(together with the spring to have conductivity)try a new spark plug.if doesnt has spark then change the coil but only the same with the old one.
bye savumihai71
Posted on Sep 16, 2009
dontbother10
  • 2220 Answers
SOURCE: wanted coil ignition module for Husqvarna 394xp chainsaw
I found an IPL for your saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 394 as model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I chose the 92-10. The coil and wire were manufactured as separate pieces. I found both at Jacks Small engines. It is interesting that the same ignition wire fits a Poulan at 1/2 the cost. About $86 for both pieces at Jacks. HTH
Lou
Posted on Oct 19, 2009
Testimonial: "Most interesting and very helpful Thank You"
Husqvarna 444 coil replacement ?
The 444 had a blue prufrex coil, and as you say it is no longer available, it is possible to fit the unit from the 254 part no. 544018301 however you need to re drill a new fixing hole, you can use the lower hole but have to drill the laminate core to fit the center hole, the upper hole is no longer used, i have done it a few times, it not easy to drill the laminate but is possible.
May 22, 2012 | Garden
Hi what size bar do you reccomend for a husky 444 se
They were offered with 13,15,18" bars, most were sold with 15" .325 pitch 058 gauge part no. 508912164 bar ans chain 501840464.
Regards
Sep 12, 2011 | Husqvarna Chain Saw 20" Bar
What is the gap setting for the ignition module ? Regards GMF
ignition module gap is generally 0.25 feeler guage
Feb 21, 2011 | Husqvarna Garden
I need the price for dell empty box dimension 5150
The best way to get this is any close by computer accessories or sales and service center.
If you are in US.. you can get this from any departmental store like bestbut, costco, walmart, office depot etc.
You can see the box, its design and dimension etc and place the order.
Else, Contact Dell Support to Order One.
Dell Customer Care #
0844 444 5818 or Sales # 0844 444 4699
Regards,
Ron
Feb 16, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How to check inition coil using meter
The best way to check the ignition module is operation on the saw. Assuming nothing happens when tested with a fresh plug set at 0.020", remove the side cover to expose the flywheel and ignition module. Remove the wire that runs to the ignition switch and try for spark again. If still nothing, use a thin business card for a gap gauge, turn the flywheel magnets under the module poles, and loosen the mounting screws for the module. Allow the poles to contact the magnets through the card, then re-tighten the screws. Try for spark again--if nothing, replace the module using the above procedure. Hope this helps!
Aug 10, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
hi
bye savumihai71
Apr 27, 2009 | Husqvarna Chain Saw 20" Bar
90 Subaru Legacy with no spark
Have you checked the ignition fuses, or checked for power to your ignition module? You have everything else covered! I hope these ideas will get you running. Best wishes.
Jan 20, 2009 | 1993 Subaru Legacy
Codes for chorus
Download BigMaq toolbar, this provides all the codes +updates
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Repaired Husqvarna 41 chainsaw won't start.
Hi
The off switch of the chainsaw has to establish the continuity to kill the running engine.First check the switch with a measure apparat.Then check the continuity of the two wiring harness,sepparately.One wire is atached to the ignition module with a screw and goes to the off position of the switch.The other one towards the on position of the switch.Check the spring!
regards savumihai71
Oct 26, 2008 | Garden
LM90 ( LOGIC MAster ) communication with 90-30 series
Try "COMx 9600,E,8,1"
LM90 is a DOS package. I assume you are using DOS 6.xx to use program. Windows will not allow DOS program to access com ports. Use a VB, C++, etc to access PLC. Be very creative in programming... convert ladder instruction to HEX with checksums.
Good Luck.
Jan 11, 2008 | Computers & Internet
Husqvarna Chain Saw 20" Bar Logo
630 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
