Question about Home
Could you let me know what i need to do, having fitted a new bath, to tile around the bath.Do I have to make up a frame
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Make sure the tub has a lip around the two sides and back if you plan to use it as a shower, otherwise you will have water leaks. yes you need to build a standard frame whereever you plan to tile, use green or blue moisture resistant drywall as well. you will need a sturdy base for tile or the grout lines will crack and let moisture in which will eventually cause the tiles to loosen. you can be creative though and build in a shallow shelf to hold things etc. just keep the moisture un mind if it will be a shower and use appropriate flashing if needed.
Posted on May 29, 2010
3 piece tub needs to re-caulked. Is this a do it yourself project?
Are you talking about caulking around all sorts of small tiles, or is yours a one piece wall unit that only has caulking around the edge of the tub and the nozzels? If it is the latter, you simply remove the old and add new. If it is all the old tile caulking then If you are not good at handyman (handywoman) things, then you should call a professional. Most of the home outfitting places have help available to you if you wish to DIY the job. You should visit a place like Home Depot, Lowes, etc. for their free advice and a lot of them offer classes in home repair things.
Jan 26, 2013 | Home
We are staying in a rented home with a spa bath. Attached to the spa bath is a hand held shower. The showerhead rests above the bath but the pipe coils somewhere between the tiles and the bath and can be...
The grout between tiles is just for filling the gaps. The tiles are glued to the wall, usually with "thin-set" mortar. Unless that mortar is in very poor condition it is unlikely that you would be able to remove that single tile without breaking it. The wall behind the tile might be water-resistant drywall (a poor quality situation) or it should be cement-board. I suppose it's possible that there is already a hole in the wall behind the tile, but the hole would be smaller than the tile, and assuming 4 inch (not large) tiles, this is a poor choice to gain access to the pipes. The usual access is through the wall from the other side. During initial construction, a removable access panel is sometimes provided (depending on local building codes and whims of the builder). If there is no access panel, and the other side of the wall is drywall, then cutting a generous hole, and fashioning a plywood panel (with trim around the edge to cover the gap between the drywall and the plywood) is a pretty standard and simple approach (depending on your skills). As an alternative and for more info, here's a link describing how to install a plastic snap-in access panel. Good luck! http://www.diylife.com/2008/06/23/plumbing-access-panel-installation/
Jun 01, 2011 | Home
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
How to put bath supports onto new fibre glass bath.It does not have a wooden frame, do I need to make one?
You mean a tub surround? You have no box for the tub to sit in? What were planning on using to hide the sides of the tub? Most big tubs, whirlpools, jacuzzis, etc, sit in a frame work of two by fours and plywood, the ply top supports the tub and the tile, The ply walls or tile board walls are needed for the tile, access to the motor is necessary if you don't have a panel on the tub itself. The tub is set in a finished box, all the tile work done on the top, and set in a ***** of concrete for support. This is for tubs with no sides on them, some tubs have one side finished, and they go up against the walls, and get tiled over the lip. But they get set in mud too. But no walls, just a band against the wall for support. I have seen every tub in every house we have worked on for 25 years done this way, it works. Check it out. Hope this helps. And I hope this is what you are talking about.
Jun 01, 2010 | Home
My tub surrounding is about a half a inch wide
You may want to try to find some thin ceramic tile beading and gluing it in place and caulking the remaining gap. Use a waterproof construction glue. This is most likely to be something you customize to fit. Often you can rent a ceramic wet saw and cut tiling to fit the need. Use proper safety gear, and be particularly careful if ripping thin pieces less you gain the nickname stubby.
Oct 07, 2009 | Whirlpool Safety Bath Walk In Bathtub -...
In my bath the shower and/or tap on/off and temperature control unit is fitted independently on the wall. The plastic plaque covering the plumbing connection has progressively become cracked in three...
You will probably find, that the unit is 'Obselete'
And replacement parts, are not being produced anymore.
Why not change the broken piece, & do some fancy tiling around it.
I recently tiled around a circular mirror in bathroom, and actually it almost looks like a window.
As long as your 'finishing' is up to scratch.
Good luck with that, & don't forget to rate:)
Jul 28, 2009 | Home
Waste trap under bath leaks
put the putty under the flange where it makes contact with the inside of the bath, push the flange to the bath & tighten nut underneath. Trim off excess. Have an overflow pipe [not intergral] make sure the top & bottom of the collar have rubber seals
If the whole lot is plastic there may well be a leak down & along the thread of the waste.[it comes from the o/flow pipe collar] Silicone the thread and tighten nut. make sure it's dry first - silicone & water do not make a happy couple
Jan 26, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
How to install claw foot bath to tiled floor
Hi giacomjo,
I'm Harvey the Master Plumber.
Your question is: You have a claw foot bath to install in a tiled bathroom. How do you fix the bath to the floor so it is secure and doesn't move?
A little clear silicone caulk under each claw is my favorite method. Locate the tub in it"s final position. Set up the drain and water connections so that you can complete them without moving the tub. Lift each end in turn just a bit and aply some caulk, you may need a helper. Wipe off the excess. Then hook up.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Home
Fitting Electrical Shower -electrician will do final connection at consumer unit
Sorry,
Thought the service was free
Silly me, only found out it wasnot after I had typed the questioin and thought it would then be aired on the forum anyway
Thanks anyway,
Roger
Jul 31, 2008 | Kitchen Appliances - Others
Home Logo
103 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
