Question about Intel Motherboard
PC not booting after bios update message. checked RAM, HARD, VGA and replaced bios battery but still can't boot.
  • Stu Morris K May 29, 2010
    can you tell me do you get nothing on screen and do you hear any post beeps from the pc if you do how many beeps if nothing at all your update went wrong if you have a floppy drive you can fix this if your bios chip is fine ,,however its not for the faint hearted it can be difficult to revive your pc even for a pc technician
  • 30 Answers
This sounds like a bad BIOS flash. See if you can revert to the previous BIOS
Posted on May 29, 2010
Vostro 200 vos200
One possibility is a dead BIOS (CMOS) battery. If you open the case to expose the motherboard, searching you should find a flat silver battery, about the size of a quarter. On the surface will be a number, likely CR2032 (maybe CR2025). The current from this battery refreshes and maintains the volatile data in BIOS, such as date / time etc. If the battery died, the BIOS will return to factory default settings. In the event the system has been altered in some way (replaced hard drive, custom RAM with different voltage requirements...), default BIOS settings may block boot-up. How to test? Power up, enter BIOS, check time. If time/date are off, the battery has likely died. How to fix? The batteries are available many places (Radio Shack, Amazon.com, maybe Walmart.. ) for less than $1. Replacing the battery, powering up, entering & refreshing BIOS {AKA "setup"}, saving settings & exiting BIOS MAY trigger the system to boot, as BIOS is capable of self detecting settings for certain components.
{Note: replacing a dead battery first is recommended but is not technically required while testing. If plugged in, BIOS should retain settings between boots).
Depending on the BIOS and any hardware changes made "post-factory", booting MAY require determining and manually entering BIOS settings for non-factory components(e.g.: RAM voltage, timing, etc.). Custom BIOS settings and other complicated solutions are beyond the scope of this introductory "Quick Fix" solution.
Nov 05, 2013 | HP Compaq dc7100 PC Desktop
Unable to POST MB
Try first resetting your BIOS configuration to bring it to its default settings and that should do the trick....
Hope that helps.........
Jul 06, 2008 | Intel Motherboard
When I boot up the screen remains blank, although the power light is on and the drive seems to be spinning. I tried unplugging the power, removing the battery, replacing the battery and re-booting but...
try to connect it to an external monitor or a tv that got vga input, if will work on it is a display problem
if not, try to take out the back cover and remove RAM memory, replace whit one that u know it work(same fsb or smaller)
if not work to try to reset bios(removing bios battery)
are more things that u can try, but are morecoplicated and are risks in them so i just put the simple tests that u can make
best regards
Sep 22, 2011 | Lenovo 3000 C100 Notebook
I have an Acer TravelMate 4500 512Mb Ram an 80GB HDD, which doesn't run the operating system boot after bios boot. when I swich on it comes up a bios boot and after that the laptop screen's becomes...
1. Remove or Unplug any recently added hardware.
2. Remove and replace the battery.
3. Press and hold the power button for 7-10 secs to power ON the computer.
4. Try booting to windows Operating System in Safe Mode. (Press F8 key as soon as you restart).
5. Check if the Hard Disk is detected and listed with its capacity of 80GB in BIOS. (Press F2 as soon as you restart).
6. Reset BIOS to default values.
7. If computer boots to windows in Safe Mode, then perform a system restore to an earlier date.
8. Install any updates available for BIOS.
9. If Hard disk is listed in BIOS, perform system recovery using the recovery partition or the recovery discs.
10. If Hard disk is not listed in BIOS, contact any nearest service center to get the computer serviced.
Jul 23, 2011 | Computers & Internet
Hi I have Dell Vostro 1520 Laptop ( Intel Core 2 Duo)/WinXP, 4Gb RAM/ Intel VGA graphics adapter . Inwhich Blue screen is coming having error message 0x000000EA. i have Format Hard Disk,reinstall Os,...
Video error. If not already done, update the graphics driver.
Try booting in VGA mode, if no joy then try booting to safe mode and uninstalling the graphics driver leaving the windows "vanilla" driver.
I
Jan 10, 2011 | Computers & Internet
I can not boot my hp pavilion a1720n. I get the error message below. I have opened up the case and moved the jumper and replased the battery. Award Bootblock Bios V 1.0 2000, Award Software Inc Bios Rom...
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Aug 08, 2010 | Computers & Internet
Well my cpu wont boot up it gets the the compaq screen but after that nothing i tried to boot it in safe mode recovery and normal boot but nothing happens its not the monitor and i dont think its the vga...
its not the problem of the vga signal.... try any of the following
1. take out the RAM and clean and reinsert it firmly. 2. enter the bios, check whether the booting device is appearing...it might be ur hard drive..if there is not boot device detected, try changing th e booting priorities.. and reboot 3. if your booting device is hard disc, try with the new hard disc after confirming the old is not detected in the BIOS..
and above all make sure all the connections were good
AND PLZ RATE this
Jun 23, 2010 | Computers & Internet
I have a hp pavilion a635w that will not boot up not even to bios
check if the ram if is compatible with the board
check if the battary power the bios
Dec 22, 2009 | HP Pavilion A635W PC Desktop
Main bios checksum error
You have to change the CMOS battery located on the motherboard...
Mar 28, 2009 | Computers & Internet
P4vmm2 wont boot up
Disconnect power cord, remove the button cell battery, press the power button to dissipate any stray volts, replace button cell, plug in cord and re-boot, this will reset bios to default settings.
You will get a check sum error so enter bios to re-set date time and other settings.
May 13, 2008 | EliteGroup P4VMM2 Motherboard
Intel Motherboard Logo
80 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
