Question about Canon PIXMA MP810 All-In-One InkJet Printer
An error message 5020 appeared and the machine is not working, how to solve (to reset)?
    Sergeant:
  • 284 Answers
Error [5020] is not big problem. You just need to release the scaner lock switch and turn the power off and on back. Then you may enjoy to use your PIXMA MP810
Posted on May 29, 2010
My copier machine Toshiba 7230 have error code CD10 when I'm copying. Sometimes The message "reboot machine" appear. How to solve the problem?
try pulling out the plug if that doesnt work try pulling the battery I believe by shutting it down you can reboot it. GoodLLuck to ya.
Dec 19, 2012 | Office Equipment & Supplies
Xerox workcentre 5020/Dn c1 error
i have one xerox 5020 machine, there is display showing C1 error code in first tray and C3 error code in bypass tray .if open and close the machine will be idle and ready to cpoy. there is no paper pick up in both trays. please help to resolve the problem.
Dec 17, 2012 | Office Equipment & Supplies
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I have Xerox 5016 model Photocopier , I am getting Error U4 ,some technican from Xerox advised that it can be solved by pressing some button ..? If anyone can support would be a great help.
Enter into the diagnostic mode.Press 50 then green button,press 20 then green button,press 00 then green button.Switch off the machine & Switch On.
Jan 15, 2011 | Office Equipment & Supplies
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
E000540-0001
E540 There is an upper tray ascent/decent error. (finisher)
Apr 09, 2010 | Canon imageRUNNER 5020 Copier
Error Message: High Pressure Reset/Low Pressure Reset
Your machine may need to Calibrate pressure transducer or replace new one.switch ON the machine (FOR MODEL 34700Z) & follow on screen message.You can also try the following:1# Check recovery solenoid (S1) coil & make sure it's not burne or it's may need to rebuild.if so,replace new coil/rebuild solenoid flunger.2# Check inlet low & high side solenoids (small solenoids S10-S11-S13-S14) is receiveng power & opening properly.Hope this will solve your problem
Jul 24, 2009 | Robinair Cool Tech 34700Z Recovery,...
Message error E901:press the power switchto off then back to on
cassette feed unit motor or control board are faulty. or something is interfering with it.
Dec 27, 2008 | Canon imageRUNNER 5020 Copier
Unable to initialize
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine
To clear paper jams:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_003.html?reg=us&c=us&lang=en&prod=mfc420cn_us
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 29, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
1,919 people viewed this question
old marine
old marine
