Question about Microsoft Xbox 360 Console
The wireless router wont connect to the xbx adapter
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Is it a new wireless adapter? if it is..
in order for the xbox works wireless
you need to have a wireless network adapter from xbox
if you do have the wireless network adapter if it black it has a installation disc that comes with the packet
install the disc make sure that the wirless network adapter is unplugged before you inserted the disc you will prompted an update select yes for the update once it is done installing remove the disc and turn off the console and plugged in the wireless network adapter then press the guide button the silver button in the middle of the controller and go to settings blade and choose system settings,select network settings,then configure network it must have the option for "wireless mode" select this option and select scan for network,choose your network if it ask for WEP,WPA /WPA2 this is the passcode that you set for the wireless network.after you enter the WEP,WPA/WPA2 you are connected
if it is the white adapter all you need to do is pluggin the wireless network adapter while the console is turn off once you switch on the console test the connection and you will be prompted to update select yes for the update then press the guide button the silver button in the middle of the controller and go to settings blade and choose system settings,select network settings,then configure network it must have the option for "wireless mode" select this option and select scan for network,choose your network if it ask for WEP,WPA /WPA2 this is the passcode that you set for the wireless network.after you enter the WEP,WPA/WPA2 you are connected enjoy the game =D
Posted on Jun 07, 2010
Bought and installed a usb wireless lan for my desk top, it brings up all the wifi in my area, i can connect to my wireless router i am using now with my laptop but wont bring up web pages. shows i am...
To test your Internet connection use a LAN cable, connect to your laptop to your router and if you can get an Internet connection then most likely your USB wireless adapter is not configured correctly for connecting to your wireless router.
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 11, 2012 | Computers & Internet
Wont connect to the computer or internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 30, 2010 | Belkin (F5D7230-4) Router (587009)
Acer Wireless Network Card Will Not Connect
Sometimes when you bootup and the error message = "wireless connection has limited or no connection", or has a red X on the wireless icon, it is because the router has not issued an IP address to the wireless card. Right click on the wireless connection and then click Repair.
If this doesn't work then reboot the router then the laptop, this should fix the problem
Sep 02, 2009 | Acer InviLink 802.11b (91.49C10.002)...
Bad relationship between Modem and Wireless Router.
Trying to understand the connections. It looks like the problem is FM-WR. Everything else works. Are you powering everything off when you move the router from one modem to the other?
Jun 20, 2009 | Arris Touchstone 450a (CM450) Modem
Wont work my belkin usb
All wireless adapters use the same radio channels so your adapter will work with your router. (If that wasn't the case, it wouldn't be so easy to connect to networks with a laptop with built-in wireless.)
Dec 03, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
HELP PLZ setting up o a 2wire router with gaming adapter
Could it be possible that the game adapter is out of range of your router?
Dec 29, 2007 | Linksys Wireless-G Game Adapter [ WGA54G ]...
Gamin adapter set up, plz help
Hi Shawn. Does yout PS2 connect when it is downstairs on the wireless? Reason I ask is wifi routers tend to transmit horizontally, and are very weak in vertical transmittions.
If you are connecting while you are own stairs, we can assume the WEP is not an issue.
WEP setting vary on different adapters. Some allow your to use 5 digits for your wep code, others require the full 10 digits. If you are using just 5, say 12345, try putting a 3 infront of each digit, i.e. 3132333435. If you are using all 10, on bought the adapters, this shouldn't be a issue.
Of course, if you can connect to while downstaris, this issue it mute.
You can also try changing channels. Channel 1 has more range than channel 8.
The last guess is that yoour router has less range than the Dlink.
See if any of those suggestions help, and let us know.
Good luck.
Dec 29, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Linksys card wont light up
ensure that the wireless adapter switch on the pc is turned on.
also check "network connections" to verify wireless adapter in there and fuctioning properly.
Nov 18, 2007 | Linksys Wireless-G Broadband Router
Hooking up my gaming router
There is a 90 % possibility that the wireless settings on the gaming adapter and the router are not the same. Try to reconfigure this again. Remember that the gaming adapter's wireless settings needs to synchronize with that of the router to make the gaming adpater works. Call netgear and verify the settings on your wireless connection and reverify the settings you have on the adapter. For manual instructions, see user guide at www.linksys.com/download
Oct 15, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Microsoft Xbox 360 Console Logo
75 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
