Question about QuarkXPress
How can I install my Quark 7 on my new Windows 7? All I get is 'QuarkXpress 7 requires that your computer is running Windows XP or Windows 2003. Help!
    Problem Solver:
  • 7 Answers
As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
Posted on Mar 23, 2012
    Brigadier General:
  • 10,406 Answers
Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application.
Tell it that the software to be installed is on a CD-ROM.
Posted on May 29, 2010
I purchased Quark Xpress back in 1990 or so, and the installation discs were the old 3 1/4 discs. I paid for updaters, and at updater 6.1, I still have the Quark CD, but some of the original Quark Xpress...
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4.1 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
In fact, if you look into the .DLLs under Windows, you may find versions of the same .DLL that can run under 64, 32 and 16 bit environments. I suspect it will work under Windows 8 if MS doesn't leave working procedures ALONE!
May 20, 2011 | Quark Academic QuarkXPress 6.1 for PC
Can you run quark 4.1 under windows 7
Please! I am using Quark 4.1 on Windows 7 64 bit just as I did on 98, XP and Vista. Without a floppy, I had to copy the installed Quark directory to newer platforms then drag out a shortcut to the desktop. I just published some work to embellish in Acrobat 10. The installer doesn't work; Quark does! I expect it will work in Windows 8 if the MS programmers don't screw with procedures that work fine now.
Oct 04, 2010 | QuarkXPress 4.1 for mac
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
Problem with Quark 7 not being able to run on my Vista based PC
Presently it will not work, but they are working on it. See the article:
www.crazyleafdesign.com/blog/quarkxpress-doesnt-run-on-windows-vista
Nov 09, 2009 | QuarkXPress
Want to convert Quark 7.3 file to Quark 4.1 so it can be read by InDesign.
Thats not possible.
QuarkXPress 7 would allow you to downsave to a QuarkXPress 6 document but not to QuarkXPress 4.
you would have to open the document in QuarkXPress 6 then save to version 5, then open the same in QuarkXPress 5 and then downsave to 4
Sep 25, 2009 | QuarkXPress 7 Full Single User Mac/Win...
Quark 6.52 locks up with new MacBook.
Which is the operating system, if its 10.5 then QuarkXPress 6 is not tested and certified with Leopard.
you can try creating a Preferences folder with P in upper case under HDD>>Applications>>QuarkXPress 6 folder and check the results
Apr 20, 2009 | QuarkXPress 6.5
Will Quark 4.1 for PC work with Windows XP?
QuarkXPress is not certified to work on windows XP, you have to upgrade to QuarkXPress 7 or 8 in order to work with it on XP
Jan 26, 2009 | QuarkXPress Passport 4.1 (112283) for PC
Quark XPress 4.1
quarkxpress_56302.jpg Related Tags:
  • quark
  • xp
  • windows 7
  • windows xp
Problem with Quark QuarkXPress
Posted by avatar15.jpgNervousFlyer on May 29, 2010
Solutions (2) Start the Windows "Program Compatibility Wizard".
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
MikeE
Jan 04, 2009 | QuarkXPress Passport 4.1 (112283) for PC
6.52 KERN_PROTECTION_FAILURE
Please let me know when exactly does QuarkXPress crashes
May 28, 2008 | QuarkXPress
QuarkXPress Logo
4,063 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Michael Galve
Michael Galve
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
