Question about Panasonic KX-TGA101S Cordless Handset
Need additional handset for Panasonic KX-FC235
Both the fax/answerphone and phone KX TCA121E are discontinued.
Is there a current phone that will work with the Panasonic KX-FC235
fax/answerphone?
5 Suggested Answers
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
SOURCE: handset volume on Panasonic KX-TGA101S is too low
Thanks for the user manual. This is the only place online I could find it...the other manuals are for installation only. I learned to push the up or down arrow on soft keys to make volume louder or softer. They have changed the page number. I found this on page 16.
Posted on Jun 03, 2010
  • 5424 Answers
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Posted on Jul 28, 2010
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
SOURCE: Panasonic cordless handsets all say line in use
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
User Manuel for panasonice cordless phone kztgea20
Do you mean the KX-TGEA20 cordless handset? I don't know of any KZ models in the Panasonic product line. If you do have the KX-TGEA20 handset, then Panasonic has the manual here: ftp://ftp.panasonic.com/telephone/om/kx-tgea20_en_om.pdf . You can also find the manual on the product page, http://shop.panasonic.com/search?q=KX-TGEA20# . Select the S or B suffix depending on the country in which you use the phone.
If you need additional information on using the handset, check the manual for the base system. The KX-TGEA20 works with the KX-TGE210 and other models. The KX-TGE210B manual is available here: http://shop.panasonic.com/support-only/KX-TGE210B.html . The direct link is ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf .
I hope this helps.
Aug 02, 2016 | Panasonic Lands Phones
Is there a built in answerphone in this model?
HI.
some info on your model.
Product Name : Panasonic KXT7630
Product Rating: 0 out of 5 (0 Rating ) Category: Home Telephone Brand: Panasonic Type: Digital corded handset Caller ID: Without Caller ID Ringtones: Standard ringtones Speakerphone: With speakerphone Number of handsets: 1 handset Messaging functions: No messaging supported
riz.
Mar 10, 2009 | Panasonic KX-T7630 Corded Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TGA101S Cordless Handset Logo
157 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
