Question about Toro Garden
Trimmer 1100 / 51317 SER.1002778 12000 RPM MAX. 220V. 50HZ 320W HELLO, I am French, sorry for my bad English! I burned the Switch on/off and the condenser... can you help me to finD one? Thanks Jean: jca@elogecreation.com
siawolf
  • 749 Answers
SOURCE: Slow Hard drive
That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
Posted on May 08, 2009
  • 9 Answers
SOURCE: PROBLEM DRIVERS
Go to the Holux support website at:
http://www.holux.com/JCore/en/support/downloadCenter.jsp
NOTE: All quote marks are added by me for emphasis only.
Under the "Select products Catagory" dropdown choose "GPS Receiver/Data Logger".
Under the "Select products series" dropdown choose "Mouse Type GPS Receiver" and
click on Submit. A new page opens showing various receivers. Scroll down to the GR-213u
GPS Receiver and see the one called "GR-213u Driver Program-Vista Driver". It is of a type
of file compression called "rar" which may require a unzip program. I use a free program,
"Secure Zip for Windows". Click on the little yellow box at the far right of the "GR-213u
Driver Program-Vista Driver" line. It will be labeled "9618869.rar". Save the file.
It should be found by clicking on the Vista START and then your user name & should be in
the "Downloads" folder as "9618869.rar".
Creat a new folder for the actual unzipped file by clicking on the the Vista START Icon
& then "Documents". Click on the "Organize" tab & then on the dropdown "New Folder".
Name the new folder "Holux Vista Drvr" & then open it.
Now back at the "Downloads" folder open (Unzip) the "9618869.rar" file. Copy the new
folder "GR-213u Driver Program-Vista Driver" to the "Holux Vista Drvr" folder you created
in "Documents", so that you can later delete all those files that may have built up in
"Downloads"folder from doing lots of downloading.
Open the "GR-213u Driver Program-Vista Driver" folder & see the setup file
"PL2303_Prolific_Vista_3301.exe". The size should be about 2724 KB. Open it to start the
driver install. Now you are almost done.
After Vista has done its driver install, go to "Control Panel" & open "Device Manager".
Now plug in your Holux GR-213 & the "Device Manager" should now show a new entry
called "Ports (COM & LPT). Click on the little + sign to expand it & you should see
"Prolific USB-to-Serial Comm Port (COM#)". The # represents your Comm Port number
used by the Holux. Right click on "Prolific USB-to-Serial Comm Port (COM#)" & click on
the dropdown "Properties". Click on the tab "Port Settings"at the top of the "Properties"
window. Change the value in "Bits per second" from 9600 to 4800 & click OK.
Hopefully you have installed the Holux Utility "GPS Viewer" with a shortcut on the
desktop. Open the "GPS Viewer" & click on "Scan". A new window "GPS Scanning" opens
showing GPS found at the same Comm Port # that shows in the "Device Manager". Click on
OK & the scan window closes now showing the same Comm Port#. Click on "Open GPS" &
then on "Cold Start or Warm Start" & all the satellites found should show up. You can close
the "GPS Viewer" & all the other open windows. If all went as described any software you
used with Win XP using GPS should work OK now with Vista.
Now run your software (MS S&T or whatever) & make sure its GPS Settings show the same
Comm Port# as in "GPS Viewer" & baud rate of 4800.
Posted on May 09, 2009
  • 145 Answers
SOURCE: 110V 6ohz - 220V 50hz
Kitchenaid mixers are not recommended on the use of a converter as they are not tested under such conditions. Understanding this, using a convertor on your mixer may automatically void the 1 year warranty regardless of age.
There are international Kitchenaid dealers available if you are requiring 110V. You may contacted Kitchenaid Customer Service for more information.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
SOURCE: Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Posted on Jul 30, 2009
  • 35 Answers
SOURCE: Hello. Pfaff 2048 I have. I have it fixed two...
If you want to fix the sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
Can i use a 50hz 220V SPLIT TYPE AIRCON TO 60HZ 220V
you probably can but it will be damaged over time, you would need to replace the motor inside to handle 60hz using the 50hz can do damage to the motor, or even cause a fire. also if it has a power capacitor that asys 50hz on the power line to the unit inside this would been changing as well.
Jun 29, 2017 | Heating & Cooling
What size run capacitor should I use for wolf electric lawnmower 220v with. Rpm 2850 and. 50Hz
Sounds like a flux capacitor. You probably need one sized at 1.21 gigawatts.
Dec 26, 2014 | Electric Garden
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
My new andis t outliner making a loud noise
The Andis T-Outliner that you purchase from the USA is not for UK voltage 220 50 HZ, the Voltage is too high, the only way to control the voltage is transformer from 220V to 120 V. The Andis Trimmer that may work for you is the GTX trimmer this trimmer was manufactured for Canada and there voltage is 220V 50HZ.
Manny's Sharpening 323 237-2885 f175053b-23eb-4546-bbc5-bb86bc86dcf9.jpg Manny Mobile Sharpening and Clipper Parts Supplies
Mar 04, 2014 | Andis T-Outliner Hair Trimmer
Good luck.
May 19, 2010 | PfaFF Quilt & Craft Pro 7530
I need help for something stupid!
It will switch Off automatically, just leave it as it is.
This voice recorder does not have any particular power on-off switch so it will switch off automatically.
Thanks.
Nov 05, 2009 | Sony ICDP620 Digital Voice Recorder
Picture djust
Put it in the custom mode.Put the contrast to the max.Put every things in middles may be colors for less.Now u have the desire ajustment u want?
Aug 19, 2009 | JVC AV-27530 27" TV
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Garden Logo
43 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
