Question about Cuisinart Refrigerators
Empisal mod.151 problem poducing flat knitting
I have just borrowed a fiends empisal chunky kitter mod.151 and am having a problem wth it. I can get it going and can produce some nice pieces but unfortunately once these peices of knitting are taken of the hooks on the machine they curl inwards and as im trying to make a scarf this is oviously not ideal. Please help wha can be done to correct this problem.
Arpi
  • 326 Answers
SOURCE: lcd blank but can hear picture being taken
Maybe the CCD imager is dead. Please contact your nearest Sony Service. If you need more info please advice
Posted on Mar 20, 2007
  • 3 Answers
SOURCE: skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Posted on Feb 27, 2008
SOURCE: need instructions childs singer knitting machine
this site has quite a few good points. farther down the page it has serveral machines and how to use them. http://www.waynesthisandandthat.com/knittingnancys.html
Posted on Apr 29, 2009
SOURCE: GR8 GEAR knitting machine
Had the same problem, couldn't find written instructions but if you search for "circular knitting machine cast on" (or off) on YouTube you'll find video demonstrations for a nearly identical machine. These worked for me.
Posted on Feb 28, 2010
SOURCE: Hi, I have Wahl hair cut
Most probably it must be operated on 110 V current. never directly supply 230V Ac in available in UK. Use a converter. it is cheap
Posted on Nov 08, 2010
Where can I buy needle bed screws for Empisal knitting machine?
Take a screw with you to home depot they many have one with the same thread pattern
Nov 28, 2017 | Sewing Machines
I seem to be missing a tension guide for Empisal sk280 knitting machine. Can I buy one
Sorry this site doesn't sell parts or have access to any parts books . Try a local small appliance repair shop for help with this.
Oct 12, 2016 | Sewing Machines
We lost or start-up manual for a Empisal Chunky Mod 151 knitting machine.
You may contact the manufacturer for a replacement manual. I also found this site online which has some of their other models manuals.
http://www.aboutknittingmachines.com/SilverReedManuals.php
Nov 24, 2014 | Sewing Machines
How can I substitute one knitting yarn for another?
don't know the type of wool you are speaking of, bu you need to identify what yarn type it is, ie double knit, 3 ply, chunky, etc.... and then you can just purchase wool that has the same ply and it should knit up the same as the Rico -just checked Rico its a super chunky its thicker than chunky which is 12-16 ply, so very thick. Ask for a wool that knits up on number 10 needles and is close to roving
Oct 29, 2014 | Sewing Machines
Free download instr manual empisal kh-680 knitting machine
Have you tried google search, hope you can find the link there for a free instruction manual download.
Oct 24, 2013 | Sewing Machines
Hi, Could you please tell me if I could knit 100% cotton( peaches/creme) dish rags on my Bond knitting machine? What size plate would I use? Thank You R.R.
You can use between a sport weight and chunky weight yarn. You can also use fancy yarns such as mohair (or brushed yarn) and boucl? as well as different yarns mace from acrylic, cotton, wool, mohair and lots more.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Bond-America Ultimate Sweater 01008-9
Refrigerators Logo
44 people viewed this question
Top Cuisinart Refrigerators Experts
Darrell
richie46
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
