I have an acer aspire 8930g laptop and suddenly the audio system has gone, both internal speakers and externally connected surround sound system. any ideas? have gone onto audio devices: it says speakers are working, digital output device working and HDMI output not plugged in. when running 'test speakers' they work!! many thanks.
    Problem Solver:
  • 12 Answers
Uninstall it then reinstall its missing a file basically, or your on safemode
Posted on May 30, 2010
Where is the audio output on my aspire 4540
how did you connect external digital speakers when you cannot find the audio out port.that is the port where you connected.ok. try installing drivers for your system to get sound
Apr 07, 2012 | Acer Computers & Internet
I have a Creative Inspire 5200 EAX 5.1 surround sound speaker system that I want to use with my Acer Aspire 5738 laptop. It works fine with my desktop but when I connect it to the laptop, two of the...
The laptop normally not support 5.1 home theater you purchase new external 5.1 sound card and it connect your USB port of laptop. Home theater connect through sound card
Apr 26, 2011 | Acer Aspire AS57386444 (LXPF702102) PC...
Apr 26, 2011 | Acer Computers & Internet
Hii sir ,,,my problem is intenal audio speakers is not working......bit working for external.......this cause a huge problem to me...........sir show me the solution...............
If your external speakers are working and your internal ones are not then it's either a loose connection with the internal speakers or the speakers themselves are not working anymore.
I would try the following; check for viruses, spyware, and malware. Reboot the system afterwards. Reinstall the sound drivers and make sure the soundcard is enabled. If all this fails then you have three options.
1. Order a set of speakers for your system and install them yourself.
2. Have a tech or pc repair shop replace them for you.
3. Continue to use external speakers.
Good Luck!
Aug 19, 2010 | Aspire Acer 4720-4538 Notebook PC
Audio card
audio card enables your computer to play music with headphone. todays computer have inbuilt audio card in them.however if your computer don't have in built one ,or u want to upgrade your sound playing capabilities of your system, u can install it.
There are basically 3 types of sound card in your system
1.audio (sound)card in *********** board
2.internal
3.external sound cards.
mother board sound card can't be removed.
However u can install internal and external audio cards and dissable motherboard sound.External card connect via USB.
Apr 03, 2010 | Acer Aspire 5500 5570-2609 Laptop
8930g with sound problems
have u download the 64bit drivers ? acer havent released windows 7 drivers for this model i recommend visting this acer link http://support.acer-euro.com/drivers/notebook/as_8930.html choose the windows vista 64 bit sound driver once downloaded install ,if problem still persists then uninstall the driver then reinstall in compatability mode for vista ;) (rite click driver then properties and select compatability then choose vista and run as adminastrator ) hope this helps
Mar 11, 2010 | Acer Computers & Internet
My internal speakers for my Acer Aspire have suddenly stopped working. However, when I plug in my external speakers, there is not problem. Please advise. Thanks
Go into the speaker icon in the bottom right hand corner of the screen and click on it and get to the mixer. In there make sure the speakers aren't muted.
If it is muted then click on it to unmute it and you should have your sound back.
If you don't have your sound back then that means either the speakers are bad or because the internal speakers hook up to the motherboard, the mohterboard could be bad.
Jan 23, 2010 | Acer Aspire One PC Notebook
The sound on my Dell laptop has suddenly gone very tinny and distorted. Does anybody know what the cause may be and how I could fix it without calling Dell in India?! Thanks
I would use the audio output of your netbook to supply signal to any external audio system so you can determine is it is an internal circuit problem or simply a failed speaker. If the distortion is present in the sound output from the external system, then a circuit in the netbook has failed. If it isn't audible in the external system, then a junky speaker has failed in the netbook.
Oct 24, 2009 | Samsung NC10-14GW Notebook
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
Acer 5610 sound problems
Hi, It is possible that: 1. You may have recently installed an add-on/external device such as a multimedia keyboard which changed the audio output from internal to external; 2. The laptop's internal speaker might have gone dead (highly unlikely but still a possibility) - try plugging in external speakers or a headset and check; 3. Most if not all laptops uses a female stereo babyphone jack to connect to external speakers. This jack has a built-in switch that cuts off internal speaker if an external is plug in. If you are using eternal or headset from time to time, it is possible that the switch might have locked to external and does not switch back to the internal; 4. You may have a hardware issue specifically the sound card/chipset. This of course would require an inshop repair which may be better off with an authorized service center. At worst is have the entire laptop replace if it is confirmed to be a hardware issue. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 09, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
290 people viewed this question
David Payne
David Payne
