Question about Whirlpool Duet GHW9150P Front Load Washer
Wont finish FH appears can you tell me the reason why
  • 24 Answers
From the tech sheets on this model, here's what FH means:
If there is no water in the unit:
—Make sure that both valves at the water source(s) are turned
on all the way.
—Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
—Verify inlet valve operation.
■ If there is water in the unit:
—Verify drain pump operation.
—Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Posted on May 29, 2010
Pioneer fh-x500ui
Your manual is here it will tell you exactly how to setup your deck.
Too much to type and this will be more complete.
Pioneer FH X500UI Manual
Jan 20, 2014 | Pioneer Car Audio & Video
It has stopped washing and is flashing FH what is the problem and what should I do ??????
First try turning off the machine for 30 minutes. Still FH? Next check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Mar 06, 2013 | Kenmore Washing Machines
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
Timer display blinks fh on maytag epic front loader
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
Need wiring diagram for the FH-X700bt
Page 16 of the owners manual tells you the color and function of the wires from the stereo are: http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/FH-X700BT_OwnersManual112712.pdf
Oct 21, 2012 | Pioneer FH-X700BT
With 26 minutes remaining FH appears where the time is displayed and the wash stops. What does FH mean
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
May 03, 2011 | Washing Machines
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Nov 28, 2010 | Kenmore Washing Machines
My thermostat is saying that the system is on, but the heat will not kick on. I have gas heat, any ideas?
my first inclination is that the thermostat is bad. The kind that tell you when a system is on or off are not reliable in my opinion. If it is ok then there are many reasons why the furnace would not come on. All of the safety switches have to close, signal is sent to the gas valve, the inducer fan should have come on first, gas valve wont open valve unless the ignition system is working.(standing pilot, spark ignition, or hot surface ingnitor). They each have there own checks for proper function. Im sorry i cant be more specific, but the information provided doesnt give me anything else to draw conclusions from. Good luck
Dec 11, 2009 | Whirlwind FH-778 Air Conditioner
I have went over checking the water lines and pressure and I even bought a new water inlet valve and the code fh is still coming on. I hooked it up just like the one that was in it. My washer is a...
The FH code means that the washer isn't detecting water at the flowmeter. Check the wiring from the flowmeter to the control board. There was a problem with this wiring harness jiggling loose and sometimes causing this problem. If that doesn't clear up the problem then I would consider checking the water level switch. Test it with a multimeter for continuity. A lack of continuity would indicate a faulty switch, perhaps stuck and telling the washer that the tub is already full and not allowing water flow to begin. Hope this helped and best wishes.
Aug 05, 2009 | Washing Machines
Ricoh 2045 sc 990 when i fix printer its appear
Did the donner copier have a finisher on it? The code means a miss comunication with the finisher. There is a HD that is used with a finisher. The meter count can not be changed that I know of......The reason it shows 000000 is that the battery was disconnected from the eprom.
Mar 14, 2009 | Ricoh Aficio 450 Copier
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
