Question about Cycling
Tiagra shifter not clicking into position. Can't change front gea
The Tiagra 2 ring setup I have on the front of my bike is giving me grief.
I can push the big lever to move it up to the big ring, but it won't click into position so it won't change :(
Ive detached the cable from the mech at the moment as I thought it might need to just click back, but this doesn't seem to have helped.
Any ideas?
Thanks
    Brigadier General:
  • 8,546 Answers
It's probably just a matter of adjusting the derailleur limits and the cable.
http://parktool.com/repair/readhowto.asp?id=75
Posted on May 29, 2010
Hot to use Shimano Tiagra FD-4400 on a triple front mech?
Can't tell what's wrong without knowing everything you've done. Try just going through the Park Tool procedure from start to finish, skipping no steps. http://www.parktool.com/blog/repair-help/front-derailleur-adjustment Front Derailleur Adjustment
May 13, 2017 | Cycling
I need to find a explosive view shimano tiagra shifters but not the one on the shimano website. I need to rebuild them from scratch.
This is very difficult to find, if not near impossible. The one on Shimano's site is the best detail there is available to the general public.
The Tiagra STI shifters and all Shimano Shifters are not specifically designed to be rebuilt and are very difficult to put back together, I do not recommend it. You can do some basic disassembly and reassembly but a complete rebuild is very, very tricky. Some of the internal gear parts are not designed to come apart and go back together with standard tools.
What is the problem with your shifter that makes you want to rebuild? I would be happy to help you diagnosis the problem before you destroy the lever.
Dec 27, 2010 | Cycling
With Shimano 6603 Group can you use Shimano 5703 shifters, or even triple Tiagra shifters?? Thanks for the reply
The answer is yes and no.
The 5703 shifters will work both derailleurs and match the 6603 group as they are both 10spd.
The Tiagra will not work because it is 9spd, it will functionally shift the derailluer but you will not be able to line up the gearing.
The rear shifter needs to match the number of gears on the back (cassette) in the case of the 6603 group that is 10spd, so you can use any 10spd rear shifter from shimano. The Tiagra is either an 8spd or 9spd depending on the model and will not work with the cassette. You can use a 6603 rear derailleur with a Tiagra group, as long as the shifter and cassette are both the same.
Dec 14, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
Shimano tiagra 9 speed shifters how to change gear
Go to http://techdocs.shimano.com/techdocs/index.jsp
Search in drop down list to go to all tiagra items and identify your particular components. Shimano are good at numbering their parts and you should find the number you seek on the bicycle component. You will usually be able to download an exploded parts diagram and service instructions. The service instructions are prefixed by the letters SI.
Nov 21, 2009 | Cycling
Shifting problems/Tiagra STI Flightdeck
It sounds like the limit screws on your derailleur body are out of adjustment. They are usually small phillips head screws on the body of the front and rear derailleur that limit the travel of the derailleur body on the rear so that the chain cannot get shifted into the spokes or off the smallest cog into the frame. On the front they prevent the chain from shifting off the inside or outside cogs. There are good articles under front and rear derailleur adjustments at this site:http://www.parktool.com/repair/byregion.asp?catid=53 I hope this helps.
Aug 11, 2009 | Cycling
I have Shimano Tiagra STI Shifters on my new touring bike and am struggling changing from the small ring to middle ring. I have been a cyclist for years but never used ergos before. Am I correct in...
If you only have 3 cogs on the front then you should only have to click once.
I currently own the same shifters as you and to me it sounds like your Front duralier needs adjusting. Use the two screws on top to adjust the limits (one screw determines how far it goes left and the other how far right) make it so the duralier can go from one side to the other without knocking off the chain. If you hear clicking or rattleing of some sort simply twist the black thing on the cable coming out the back of the rear duralier until it stops
hope this helps
Aug 05, 2009 | Shimano Cycling
Cycling Logo
277 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
