Question about Haier HLP21E Top Load Washer
Where is the lint filter located on this washer?HLP21N
Where is the lint filter located on this washer?Thanks
  • 159 Answers
Hi.It may be that these machines dont actually have a lint filter,they are making alot of them without lint filters now days.There would be a button trap down at the side or the rear i would imagine for cleaning out debris such as coins,hair pins,Etc.
Posted on May 29, 2010
Testimonial: "Thanks!I will check it out."
  • chrizzoclark May 29, 2010
    Your very welcome.
The lint filter is inside the barrel itself and looks like a long rectangular box that insert itself neatly in the side. It has a little handle so you can take it out from its encasement, open it like a box and empty it. I don't think the previous owner of my machine knew about that either because it was so clogged that, at first, I thought there was a filter in there....
Posted on May 06, 2015
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
Need to locate lint trap on washer....affinity frigidare front load washer
There is no lint trap on this washer. There is a filter in the hose that goes from the tub to the pump that occasionally will get plugged with lint, but it is not designed to be regularly cleaned. During normal usage, the lint is designed to be pumped out with the water.
Kelly
May 25, 2011 | Washing Machines
Clothes have lint on them when washed. my old washer had a lint filter, do not know where the lint filter is on the Maytag Atlantis. Help
The lint scree in inside the hose on the inlet side of the pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Does this washer supposed to have a lint filter
No Lint Filter sorry you have a basic design washing machine, Dont replace it though it wont do u any justice just pocketbook pain
Jun 17, 2010 | Kenmore 44932 Front Load Washer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Washer will pause in mid cycle, once you push the pause cycle it will run for a while then will pause again, after about 5 to 6 times a load it will complete.
Hi
Thanks for using FixYa. You’ll need to clean the filter which is located on the front bottom of the washing machine right below the washer window. It is held up by three screws. Take out the screws and clean the lint. You’ll find in the lint some small clothing, coins and other small things.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | GE WSXH208A Front Load Washer
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Looking for the lint filter
you did not give me a mod # of your washer .... so i will go through the history of the lint filter 1955-1964 the lint filter was on the right side under the lid , twist knob and pull screen out 1965-1986 lint filter was self cleaning mounted under the washer 1987 -today there is no lint filters any more ..... lint filters where used when people hung the clothes out on the line .... today most people use a DRYER that has the lint filter in it .... i hope this helpes ....... if you are going to rate this please rate this 3 or 4 stars , that will keep me in the paid answer department . thanks
Apr 01, 2009 | Washing Machines
Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Nov 01, 2008 | Washing Machines
Haier HLP21E Top Load Washer Logo
1,670 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
