My airston a1237 washing machine is stuck on wash will not move on to rinse unless stop it and do it manually by the dial.
  • 159 Answers
This sounds like it may be a timer problem.The timer isn't advancing on it's own unless you move it.Also make sure there isn't a button or setting thats been activated to stop the draining at that point.such as a Drip dry option.
Posted on May 29, 2010
Testimonial: "thanks for your help."
Washing machine does not complete wash cycle. Gets to rinse than stops. Does not rinse or release water. When I manually move the dial to spin, nothing happens?
You need to check the pump it sounds like you have something in it .Clean out the pump and the unit will finish the cycle if the pump is not burnt out.
Sep 18, 2011 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine stops at the "Rinse" setting
Needs a new programmer as the contacts in yours are worn or broken.
May 19, 2009 | Washing Machines
Machine fills rinses and stops before drain and spin
Sounds like your timer is not moving the gears to the next cycle.
May 18, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag Atlantis washing machine
Yes there is a small motor just like in most wall clocks the gears strip or the gear bushing slips and refuses to advance the dial.
you have to replace the whole timer unless you know MacGyver microsurgery
Feb 13, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
