Question about Nokia 6600
Battery discharges too quickly, even when a fully charged battery is used.
  • Nokia Master
  • 456 Answers
May be you have problem with your battery try new battery
Posted on Apr 08, 2008
SOURCE:
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
When I go to use wi-fi, it keeps saying wi-fi is disabled. Yet, other laptops in the house work off the wi-fi
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Aug 01, 2011 | Acer Tablets & eReaders
I have not used the headphones for at least three days. Even though the headphones are on "off" they continue to keep charging and have been for a couple of days. What is the reason for the...
My Sennheiser HDR 140 headphones charge whenever you hang them on the charger. The charger will "trickle" charge them to keep the batteries fully charged. If you find when you use it the batteries discharge quickly it's time to replace them.
My batteries are about 2 years old and I still get about 8-10 hrs of use before needing to recharge
Jan 04, 2011 | Sennheiser Audio Players & Recorders
Battery will "fully" charge and then only run for 20 - 30 minutes of use then be discharged. Have fully discharged and re-charged to no avail. My other battery will run for 2-3 hours of use.
Hi Fred,
I have several 18v tool sets and for the most part I'm quite satisfied with their performance. I currently use Bosch and Ryobi.
When used with the drill, a battery can last me the whole day. On the other hand, the sawzall will eat them up pretty quick.
The thing I've found common to all brands is that it is absolutely crucial to make sure the batteries are fully charged before they get used for the first time. That first full charge seems to set the bar for subsequent charges for the rest of the batteries life.
I too, have tried the discharge/recharge thing. No help. I can only suggest a new battery and letting get all it can take from the charger the first time out of the box.
Since I've been doing that, I rarely even think to bring my charger to job sites, there's that much of a difference in performance.
Hope this helps you out.
Best regards,
Mike
Mar 31, 2010 | Bosch 18V Brute Tough Drill with Blue Core...
Quick discharge within 1day even when switch off
hm ur battery life s gone....replace it.... hope ur following the safe way to use a battery....... always charge the battery only after the battery gets fully drained!!!!! thanks for using fixya!!!!!!!1
Nov 01, 2009 | Nokia N72 Cellular Phone
Binatone Cordless Phone (2nd set) loses charge quickly
The batteries that are in most cordless phones, and even cell phones, have a "memory". If the battery is constantly being fully discharged from a lack of charging, or if it's used to being on the charger all the time, it will reduce the life of the battery substantially. You'll need to get a new battery, and try to make sure that the phone is placed back on its charger every night before you go to bed. This should allow the battery to receive a full charge each night to prevent full discharge and lengthen the life of your battery. I went through about 2 or 3 batteries once before I found this out. I'm sure that you'll find this helpful and it should save you a few bucks in not having to replace your battery as often. Please rate me accordingly, if it's not too much of a bother. Thanks and have a nice morning!
James
Nov 24, 2008 | Uniden Cordless Phone
Rapid battery discharge/non connecting calls
take the phone and have it either reflash or the main-board replaced.
May 22, 2008 | LG CU400 Cellular Phone
Nokia 6600 Logo
32 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
