Question about ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard - can it take buffered or ECC RAM modules for an upgrade???
  • 1,675 Answers
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
MAXI MUM RAM NOT SAPOT DDR 1 BOYS NOT SEVE EMEDATLE ENFRMESON PLIS
http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf
The link above is the link for the manual for the Motherboard, this will tell you what ram is supported.
Nov 17, 2010 | ASUS P5PE-VM Motherboard
Is Asus P5PE-VM series motherboard supports 2GB RAM
i have a problem with ASUS P5PE-VM motherboard, with 2 GB DDR 400 (2x1GB, Kingmax) the system (Win XP Pro or Vista) doesn't start. it hangs up in different stages.. what's wrong?
Oct 05, 2010 | ASUS P5PE-VM Motherboard
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
I have a PC with an ASUS P4B533-VM MoBo. I got
Hello.
According to Crucial, your MB takes either DDR PC2700, or DDR PC3200, NON-buffered, NON ECC modules. Another consideration is density. Some cheap high density modules will not work in all MB's.
Refer to:
http://www.crucial.com/store/listparts.aspx?model=P4B533-VM
Have you tried to see if it will POST with just one module installed? Try both individual modules and see if there is any success. It may be that one is bad.
Thanks for using Fixya.
Wayne
Dec 01, 2009 | ASUS P4B533-VM Motherboard
What tipe memory that i want to use it with this motherboard P5RD1-VM
Your motherboard takes DDR PC2700 or PC3200, non-ecc, non-buffered RAM. It has a maximum of 2GB. (1GB per slot)
See all information at:
http://www.crucial.com/store/listparts.aspx?model=P5RD1-VM
Nov 12, 2009 | ASUS P5RD1-VM Motherboard
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
Memory problem
The ASUS web site shows only two ram slots on the motherboard. Sounds as if the booklet has a misprint. Specifications on the web site list memory as: Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory. So, 2GB is max.
Jun 10, 2009 | ASUS P5PE-VM Motherboard
Does the motherboard support RAM Modules at 667MHz?
Yes you should be able to use 667MHz modules with your motherboard.
They will function at 400MHz.
Please be aware that some memory modules may be incompatible with some motherboards.
Although this happens rarely, only way to find out is to test.
Ask if you can return the modules if this happens.
Oct 03, 2008 | ASUS P5PE-VM Motherboard
Intel ASUS P4 845 GL Motherboard
Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
ASUS P5PE-VM Motherboard Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
