Question about Fantom Drives GForce 1 TB USB 20 Hard Drive
Laptop stops working when Hard Drive is pligged in!
My Hard Drive was working fine but suddenly it just stopped working! I plugged it in my laptop & it popped out a message saying that Windows Explorer has stopped working. The only way I knew on how to fix it was unplugging my Hard Drive. Then when I would plug my Hard Drive back up it would give me an Error Code, which I forgot to write down! I Uninstalled the Driver & Installed it again but the problem still remains the same!
  • 439 Answers
Call to expert +1(518)348-9393 i will fix this for you
Posted on Jul 03, 2017
  • 5 Answers
SOURCE: I/O error FDU80
Dear Enryc2 I don't know if you have found a solution already but this is what I tried. If this is your bootup drive, disconnect all other drives, eg., CDRom/DvDRW, FDD, USB drives and try to bootup. You may also try to update your BIOS(only if you know how to).
Posted on May 01, 2007
SOURCE: Fantom 120 GB harddrive stopped working
I am not sure if this is a solution, but I am a Mac user and the drive stopped working on my Mac with Leopard (OS 10.5.5) but seems to work fine on Panter (0S 14.4.). I am not sure how to fix this problem, but when I went to an older computer with an older OS, the drive seems to work just fine lik it did... I can't remember if I updated my Firewire or not.
Posted on Dec 11, 2008
  • 390 Answers
SOURCE: External hard drive shown as portable disk and does not work
i think the hard drive is ageing,
if you are past warranty try to open up the casing and try to see if you can connect the HDD to connect individually else where (like with another casing or Laptop PC) if still not connecting then the problem is with the HDD
else the problem may be with the casing
pls rate if this was any help
Posted on Jul 13, 2009
  • 6831 Answers
SOURCE: I have a Fantom Drive Titanium External USB 2.0
If you turn on the drive can you feel that the drive starts spinning? Can you feel movement and see a light flickering?
Does your computer acknowledge that there is something plug in when you plug in the Drive? Does it give you a notification, or does it make a sound?
If so, then this simple setting just might fix your problem.
Just follow these steps and you should be set.
Go to:
Control panel
Administrative tools
Computer management
Disc management
Now you should see your drive in the schematic below.
Right click on the drive and choose to change the drive letter and paths.
Now click on change and change the current drive letter. If there is no drive letter assigned, assign one.
However, if the drive does not spin at start up, there is something wrong with your HDD.
Hope this can be of help.
Kind regards
Posted on Nov 15, 2009
  • 247 Answers
SOURCE: can no longer connect to hard drive
try with back panel USB hosts
Posted on Jun 26, 2010
I've got a samsung m3 portable that has suddenly stopped being recognised
it is not uncommon for external hard drive enclosures to fail. If its not working on multiple computers, this is probably the case. try it in 1 more computer and if it still doesn't work, I would do the following:
1. Open the enclosure to expose the actual Hard Drive and obtain the model number and note the size. if its a laptop hdd, its 2.5". if its a full size hdd like in a desktop pc, its 3.5". the enclosure may be screwed together but likely snaps together.
2. Google the model # to determine the interface and speed (likely SATA 3.0gb/s but could be SATA 6.0gb/s
3. Go to or and buy a new external hard drive enclosure ($5-$35) with the same interface, speed, and size as your hdd (use the filters on the left to narrow your search)
Home Computer Hardware Computer Cases External Enclosures
4. Put your hdd in the new enclosure and check if its working.
Mar 07, 2014 | Computers & Internet
The HD suddenly stops getting recognized by the laptop, in the middle of any action.
Sounds like a conflict. Disconnect any other USB attached devices while running HD. Worked for me with same problem.
Aug 26, 2012 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
Blue screen occuring and the laptop restarts
maybe the problem of your laptop was the memory ram that was built in... or the hard drive i think...
Aug 11, 2012 | Dell Computers & Internet
My seagate 500 gig free agent desk external drive has suddenly stopped working. It was working fine 2 days ago and then yesterday it apparently wasn't connected so I reconnected it and then it seemed to be...
Do a FULL POWER DOWN Reboot. and try a different USB outlet in the PC... same Laptop to see if it is in your PC that is causing the problem.
Note: Most of those Drives do stop unless they are connected to the PC... energy savings.
If that didnt work... you could have a failed drive. Seagate should help you do some diag if it is in warranty... typically 3 years.
Dec 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Laptop suddenly stopped recognising my external USB hard drive
I had the same exact problem with a WD2500xms passport. The problem was the USB cable. I went to the store and bought a 6' USB cable ( $26 at Radio Shack) with the same specs and now, no more problems. Also I called WD technical support (800.275.4932) and asked for a new cable. The WD customer serverice was very helpful and said it would sending me a new cable for free. When it arrives I'll return the 6'er.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
My 650GB WD external hard drive has suddenly stopped powering up. The blue light flashes once & then there is nothing. It doesn't show as connected to my laptop either. I've tried switching to other...
This can be caused by a few things. Either send it in to be fixed if its under warranty. Or take it apart to get at the hard drive inside and try and plug it in internally to retrieve your files.
Jul 16, 2009 | Western Digital My Book Essential Edition...
Keyboard on hp dv7-1130us stopped working
This sounds alot like a virus i once had!
try a system restore to the point before these problems occured. if that doesnt work run a full virus scan. If that doesnt fix the problem you may have to wipe the hard drive completly.
Apr 26, 2009 | HP Pavilion dv7-1130us laptop
Computer Doesn't See Freeagent Go 250 external drive
Uninstall all usb controllers from device manager and then restart your computer. Scan ur system with mcafee 8.5i
Jan 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Nothing happens
You may not be able to fix the same. You have to find a chip level repair shop
Dec 15, 2007 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Fantom Drives GForce 1 TB USB 20 Hard Drive Logo
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
