NO COST and fast PROCEDURE TO FIX IT, if just one window stuck:
1. Sit in vehicle, on seat next to problematic window
2. Ignition key is on
3. Door in question is opened (in case you closed it)
4. While door is open, press and hold power window button in desired window travel, keep button pressed !!
5. SLAM hard the door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, but usually the first try works!
This way, try this first before spending $ at the dealer, or taking door apart to hit motor. as mentioned above post.
Remove your sidings,then you will see a strait bar thats holding the glass,unscrew it, usually it has 2 bolts,then lift the glass,put something like a rod or broomstick to hold it closed.dont forget to unplug the window terminals.
thanks for your answer, this is on my sons motor,we needed to cure problem for ever, i stripped off all inside casings and checked the power to the motor which was ok, so it pointed to the motor, applied a good sharp hit to the motor at the same time having the switch in the up position (powered) and it worked. it appears that the motor got stuck at the bottom of its downward cycle(which is not uncommen) all is still working well. again thanks
