Question about Acer Tablets & eReaders
My aspire 1810tz notebook unable to boot up. went into setup, unable to find hard disk.Help!
    Scholar:
  • 94 Answers
Try to check the connection of the hard disk inside maybe did not fixed properly. Just open at the back of your notebook where the hard disk was inserted. After that if did not works, just replace your hard disk it could be damage.
Posted on May 29, 2010
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
My toshiba r15-s822 says it has no drive and gives a (Ide#0 ERROR) i had a virus and i formated the drive a while back and i got a new windows xp install but i cant seem to load it cause it wont show the...
Xp can only "See" a hard drive up to about 128GB, if its bigger than that, XP won't install.
Make sure your drive is properly connected, and jumper in the right place (1 drive, set to master)
If it used to work before your problem, should be ok.
Then boot from your windows disk. If your bios is set to boot from the hard drive, if there's no operating system on your hard drive it can't boot.
If its set to boot from the hard drive first, it may, after a few seconds revert to booting from the disk drive. If not, while booting watch the screen, at the bottom it you should see "Press F2 for setup or F10 for boot options" or something similar. To temporarily change the settings, choose the boot options menu and select "Boot from CD". Restart and you should be on your way.
If that doesn't work, you may need a new hard drive.
Aug 23, 2011 | Toshiba Satellite R15-S822 Tablet PC
Reset bios
There's no need to reset your BIOS, only you do is to set in your BIOS Setup to boot priority like for example First Boot Priority is your CD/DVD Rom Drive, if you got some Bootable System Disc then the Second Boot Priority is your Hard Disk Drive. Good luck!
Jul 26, 2009 | Compaq tc4200 Tablet PC
Recovery CD not loading onto Hard Drive.
Your optical drive is not reading the disk properly - a common issue as time goes by. Replace drive with a good known working unit and your recovery operation will take place.
Mar 27, 2017 | Itronix GoBook XR-1 Tablet PC
Power on password locked
its some hard to do but maybe you can
. Your notebook
2. An empty formatted diskette (720 kb or 1,44 mb)
3. A second computer (e.g. a DOS desktop PC)
4. A hex-editor (e.g. Norton DiskEdit or HexWorks)
This is what you have to do:
1. Start the desktop PC and start the hex-editor
2. Put the disk in drive A:
3. Change the first five bytes of sector 2 (boot sector is sector 1) to: 4B 45 59 00 00
4. Save it! Now you have a KEYDISK
5. Remove the disk from drive A:
6. Put the disk in the notebook drive
7. Start the notebook in Boot Mode (push the reset button)
8. Press Enter when asked for Password:
9. You will be asked to Set Password again. Press Y and Enter.
10. You now see the BIOS configuration where you can set a new password
May 27, 2009 | Toshiba Portege 3505 Tablet PC
Boot up problem
this is a easy fix all you need is a windows xp installation disk.what you do is put the disk in and boot off of the cd option.if you need help with the xp cd installation i can write up a guide for you.also is the first harddrive new or came with the comp.if it is a new harddrive it might not have a operating system on it.email me if you have anymore qeustions or you want the guide.i can even make a video for you but it probably won't be good quality.
Apr 23, 2009 | Toshiba Portege 3500 Tablet PC
I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jan 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Will not boot even from recovery media disks
If you have an XP disk, or even one you can borrow, you might want to try to see if you can boot from that. I have one of those machines that I run with regular XP, I wish you well. A still small voice told me to get the extended warranty, and I am so grateful. Since buying mine in Nov 2004, it's gone in for factory warranty at least 12 different times.
Jul 15, 2008 | Averatec C3500 Tablet PC
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Cannot Load Windows/Windows Setup Does Not Detect Hardrive
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
Feb 01, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Tablets & eReaders Logo
73 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
