Daewoo DV6T811N DVD Locked
Daewoo DV6T811N DVD is stuck inside, display shows "LOCK". Unplugging the player did not help, still shows LOCK.
  • 123 Answers
Your Child Lock has been turned on.
Press the power button of the remote for about 8
seconds. No buttons of front panel and remote can be
operated now and Lock indicator (“LOCK”) will be
displayed on window display.
To release child lock,
press the power button of the remote control for
about 8 seconds.
Good Luck.
Posted on Apr 08, 2008
Thanks so much!!! My wife was in a dead panic as apparently the kids had locked the VCR.
Posted on Feb 06, 2010
2 Suggested Answers
SOURCE: Disk stuck inside player, LOCK shows on display
Try pushing and holding the power button until lock is cleared. I have a different model daewoo dvrs04 but that's how it works for my dvd. Hope it helps
Posted on Apr 11, 2008
DAEWOO DV6T844B DVD player is "locked"
Press the power button on the remote control for about 8 seconds to lock or unlock the DVD player.
Aug 20, 2008 | Daewoo DV6T844B DVD Player/VCR
Mar 16, 2008 | Televison & Video
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Display says "LOCKED", won't eject disk, all other functions work. Need unlock procedure.
How I got my DVD from ”lock” condition
My DVD (Panasonic m: DMR-ES10) had gone to ”locked” condition without any warning.
Perhaps the reason was that I transfered the machine when it was on and recording was going…
Guidebook didn´t help to resolve the problem, neither Internet. Finally I managed to solve the promlem . This is how i did step by step:
1) Power on
2) Hello
3) read
4) no disc
5) functions
6) to others
7) setup
8) select down arrow
9) disc
10) select right arrow
11) setings for playback
12) enter
13) ratings (level8)
14) enter
15) No limit
16) enter
17) ”The Recorder is now unlocked” (picture of open lock)
18) enter
19) return
20) return
After this DVD works normally.
Jalmari
Aug 11, 2007 | Sony DVP-S330 DVD Player
Child lock?
To turn on the dealer lock function: Turn the DVD player on. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds. Note: When the dealer lock function is active, DEALER LOCK ON or DEALER LOCK OFF scrolls on the FLT display. this is from samsung's site
Jun 07, 2007 | Samsung HTDM150 System
Locked dvd tray.
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears.   The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
Apr 07, 2006 | Panasonic DVD-A110 DVD Player
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
Televison & Video Logo
763 people viewed this question
Top Televison & Video Experts
Electro Med Services...
