Question about Loewe Aconda ACO9303 30" TV
Keeps turning off afer a few seconds of it coming on
Lg gas dryer stops afer few minutes
You will need to replace the solenoid of the gas dryer.
What happens is that the solenoid cannot hold the gas open for so long that closes. That's why heat stops after a few seconds.
Mar 04, 2014 | Dryers
It shuts off afer 5 seconds when powered on.
Does the unit output sound when powered on? If no sound can be heard, and you only hear a click after 5 sec. then your power circuit may have a faulty diode.
Apr 02, 2010 | Sherwood RD-6500 Receiver
I have a maytag DC68-02031A clothes dryer. When I
E 3 is not a maytag fault code . may be f 3 . I need your model & ser # and I can tell you more . thams mm
Nov 20, 2009 | Refrigerators
My Syncmaster 730mw keeps losing its picture afer a few seconds. No matter which input I use VGA, SCART, Component the picture comes up crystal clear and then flicks off after about 1 - 2 seconds! I can...
If you can make out a faint image then the fault is a backlight problem.
The fault could be an inverter board or the CCFL lamp/s
For service, parts and DIY info check out LCD Parts - click on this link to their WEB site : -
www.lcdparts.net
Oct 19, 2009 | Samsung SyncMaster 730MW 17" Flat Panel...
How do I reset my clock in 1999 ford 4x4.
off memory?????????????? when radio is on hold clk button in, afer a few seconds hrs will flash I think you use the up-down button, then when the hrs are right press the clk button again and set the minutes, when done push the clk button and it should be the time you put in.
Sep 19, 2009 | 1999 Ford F150 Regular Cab
I bought a second wii remote it is fully charged but it flashes several blue lights then switches itself off! please help
wen you go to play a muliplayer game and the second remote won't turn on automatically wen a button is pressed then with the player one remote go onto the wii menu then go onto wii remote settings ( at the bottom of the screen) then click on reconnect press 1 and 2 at the same time on the player one remote after a while it will turn on the do the same thing with the player 2 remote and it should turn on afer a few seconds
hope that helps =]
Apr 23, 2009 | Nintendo Wii Remote Controller
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Oster classic clipper smoke after a few use not electrical smoke
How do I do maintanience on my clipper to keep them running good
Apr 07, 2008 | Oster 76076-010 Hair Trimmer
Loewe Aconda ACO9303 30" TV Logo
218 people viewed this question
Top Loewe Televison & Video Experts
Josh Whitehead
Josh Whitehead
isaac johny
isaac johny
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
