Question about HP iPAQ HX2490 Pocket PC
I cant hard reset my ipaq 2490b - HP iPAQ HX2490 Pocket PC
2 Suggested Answers
  • 8 Answers
SOURCE: HP iPAQ 2490B can not be hard reset
If all else fails, remove battery from unit & let completely run down
(usually 12-24 hours), possibly longer.
Pop on charger, & unit should turn on as if hard reset
Posted on Jul 11, 2009
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
I am trying to hard reset my IPAQ but it's not resetting...I have 2 and one was successfully reset, is there another way of hard resetting the HP IPAQs? Thank you
Please go through following link to set up your iPAQ.This page has the links to reset different models of iPAQ.http://resetcellphone.com/solution/HP
It will be better if you can give the exact model number of your iPAQ.
Mar 05, 2011 | HP iPAQ 114 Pocket PC
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
My ipaq hx 2415 will not go past the ipaq screen reset screen
Have you tried a hard reset (deletes everything)
2. While holding down these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
Mar 18, 2009 | HP iPAQ HX2415 Pocket PC
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
HP 2490B SD CARD
check if your SD is SD HC because it cant read HC
Nov 04, 2008 | HP iPAQ HX2490 Pocket PC
How to hard reset hx2490b
Recovery Procedure for HP iPAQ hx2750, hx2490, and hx2790 Pocket PC Series:
To perform a Hard Reset on the iPAQ Pocket PC by pressing and holding the Calendar and iTask buttons (1 and 4).
2. While holding down the Calendar and iTask buttons, use the stylus to lightly press and hold the Reset button, which is located at the bottom of the iPAQ Pocket PC, for approximately two seconds.
3.. Release all buttons.
4.. Connect AC power to the iPAQ Pocket PC. The handheld Powers On,
performs the normal boot sequence, and automatically restarts system.
Oct 30, 2008 | HP iPAQ HX2490 Pocket PC
HP iPAQ hard reset
Scroll down on this page to find the ipaq 5000 series:
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
(H5450 and H5455 are the same ipaq)
Jul 25, 2008 | HP iPAQ H5455 Pocket PC
NO SOUND AFTER TOMTOM 6
I had the same issues as mentioned installing TomTom Navigator version 7 onto a HP IPAQ 2415 running Windows Mobile 5. As soon as TomTom was installed the sound stopped working.
I did a Hard Reset to restore the IPAQ which got the sound back. I then downloaded the trial version of WinCE Cab Manager http://www.ocpsoftware.com/products.php?nm=cecabmgr and used this to remove the files Btcoreif.dll and Btsdkce30.dll from the TomTom installation CAB. I saved the cab and then ran this again and it installed perfectly and I still had sound. Hope this offers a solution for anyone still having a problem.
Jan 13, 2008 | HP iPAQ HX2490 Pocket PC
Ipaq RX3715 hard reset
hard reset: Button 1 and 4 and press reset button with stylus
Jul 11, 2006 | HP iPAQ RX3715 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
490 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
