Question about Canon PIXMA MP160 All-In-One InkJet Printer
The scanner is not working. Everything else is working fine
    Sergeant:
  • 284 Answers
You should use a good quality USB 2.0 cable. If using low quality USB cable, you are not able to use the scanner function.
Posted on May 29, 2010
Canoscan lide 70 "unable to select twain I uninstalled everything.. this all happened after I tried to install an old canon camera. The scanner is identified.. it makes it's normal sounds during boot... I...
Looks like things have got a bit mixed up with the canon software. Try this:-
1) Un-install the camera.
2) Un-install the scanner.
3) Re-start the PC.
4) Re-install the scanner.
Mar 29, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
We use Abby 8.0 finereader with kofax VRS. We can not gt the scanner or Abby to reconize the VRS with the scanner hooked up. Everything works fine with another scanner.
Use CapturePerfect ver 2.0 downloadable free. Ver 3.0 is priced. http://software.canon-europe.com/software/0022439.asp?model= though this is under Canon 5020, it works with 9080C.
Have you loaded Device drivers, if not download from http://software.canon-europe.com/products/0010035.asp
Once the driver is loaded you can even use Microsoft Imaging to scan. CapturePerfect is easy and brings out the added features of Canon 9080C.
S. Mohan, Chenai, India
Aug 12, 2009 | Canon DR-9080C Path-Through Scanner
Hp 3030 scanner
Go to HP and download proper software, and drivers there is some scanner software in there to make scanner work.
Aug 04, 2008 | HP LaserJet 3030 All-In-One Printer
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
EPSON V700 Photo Scanner
Unplug the power supply from the power port on the scanner then plug it back in after a few seconds and power-up if it isn't already on. This happens to me a lot and this works every time. Frustrating though.
Jan 14, 2008 | Epson Perfection V700 PHOTO Flatbed...
Scanner has stopped working
When I had the cable that came with the printer connected to the scanner, and the cable that came with the scanner connected to the printer, the scanner didn't work.
Changing the cables changed everything.
Oct 15, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Image problems
The lower scanner unit moves when doing the shading adjustment (scans the little white plate on the top and bottem scanners). Most common problem is a staple interfering with the lower scanner movement.
Oct 02, 2007 | Canon DR-2580C Path-Through Scanner
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
