Question about Altec Lansing FX6021 System
No audio at all altec lansing fx6021 - Altec Lansing FX6021 System
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
  • 11 Answers
SOURCE: Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Posted on Sep 17, 2008
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
Love my speakers but not working now, how do I fix them, are there common faults?
Aztec Lansing used to be good, now not so good. My first ones went at the power source. The replacement had a hiss even with the switch turned off and the volume control was scratchy and uneven. You can fix this by lying the speaker with the volume control on its back and spraying WD40 or better still Switch Cleaner around the control and then turning the knob. Do the same for the on / off button.
I replaced mine with Bowers and Wilkins MM1. Much more expensive but quality sound from a small high precision unit. They also have full warranty.
Aug 25, 2015 | Altec Lansing FX6021 System
What is the dc voltage for Altec Lansing ACS 66i
friend chk your adapters back it must be written on it....
Jan 20, 2012 | Altec Lansing Audio Players & Recorders
Needed driver for altec lansing acs45.1
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://download.cnet.com/altec-lansing-hid-audio/3000-2120_4-81513.html
http://download.cnet.com/altec-lansing-hid-audio/3000-2120_4-80282.html
http://download.cnet.com/altec-lansing-hid-audio/3000-2120_4-80281.html
hope this helps you
Oct 16, 2011 | Audio Players & Recorders
I own a A/Lansing FX 6021, My right satelite speaker is not working( no sound, no buzzing at cable plug-in), are there any solution for this problem??
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 05, 2011 | Altec Lansing FX6021 Computer Speakers
My computer altec spekers have a hum to them
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
May 17, 2011 | Altec Lansing Speakers: FX6021 Inconcert...
Altec Lansing FX6021 System Logo
119 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
