Question about Power Acoustik P312W Car Subwoofer
What kind of amp do I need for two 12" p3-12ws subwoofers
    President:
  • 1,561 Answers
800W to 1500W is ok.
Take care.
Posted on May 30, 2010
If you want to keep a matching set up, the Power Acoustik CPT41700 1700 Watt 4 Channel Crypt Amplifier should do the job to push your 12" subwoofers to the limit. Click on the link below to view:
http://www.deffaudio.com/store/product_info.php?products_id=2649&osCsid=6511ebbdb9a7236fc624b94331cfdb86
http://www.sonicelectronix.com/item_17664_Power+Acoustik+P3-12W.html
http://answers.yahoo.com/question/index?qid=20081221221320AAfJ2iv
Posted on May 29, 2010
How do I wire the back of my 12"subwoofer?
You will need slide connectors any hardware store will have them.Your speaker wires,have one with a stripe that one goes on the side with a +(pos.) the other goes on the -(neg.).
If you do not have speaker wire at the place you are mounting the speaker,I need to know what kind and how big(watts) is your amp,the make and model of the ride,do you have a preamp,type of cross overs,and what cd player or changer you are using.
May 17, 2011 | Kicker 07CCVR102 Car Subwoofer
I need to move the amp off of my visionik vbx12a sub to the front of my car but when u remove the amp off the sub u realize there isnt a back to the amp so the its circuits are just out there so where...
maybe you can build an amp rack some where else in the car or behind a pannel but make sure you use some kind of 12 volt fans to keep the amp cool . then extends the wire to the subbox and then you have to disconnet the subbox and move it not the amp
caraudioquestion@gmail.com
Oct 14, 2010 | Visonik V15S4 Car Subwoofer
How to I install Benwin 3d surround and subwoofer speaker to my PC
You should be able to plug them into your sound card. If an adapter is needed, they can be found at almost any electronics store.
Aug 31, 2010 | Benwin BWS30 Computer Speakers
My subs r not hitn hard any more bt they stiil work n my amp is all da way up
Not making any weird noise? check your low pass filter switch on the amp, check your head deck settings, what kind of amp??
May 18, 2010 | Sony 12" Single-Voice-Coil 4-Ohm Subwoofer
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I just picked up a 12" type r in a box with a alpine m 350 how do I know what kind of type R I have without taking it out of the box?? and how do i hook it up to this amp??
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Sep 10, 2009 | Alpine SWR-1222D 12" Type-R Series...
What kind of amp should i run?
i would suggest a pro persicion amp 2400 watts thats what i run and its very decent
Jan 30, 2009 | Kicker CVR12 Car Subwoofer
How big of am amp do i need?
Depending on what kind of music you listen to I would say around a 1200 Watt Amp would suffice for what you are saying. Thank you for using Fix Ya! Don't forget to rate the overall answer to your question.
Jan 28, 2009 | Power Acoustik 12 1200w Subwoofer Car...
My Earthquake Supernova MK-IV 12 stopped working
kindly check out maybe the fuse was already explode...check the connections specially the coil of the speaker using a multi tester....thanksss and gud luck
Nov 28, 2008 | Earthquake Sound MKIV-12 Subwoofer
Box type, dimensions And wireing for a 2 12''4Ohm duel voice coil
http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html this website will help you out with wiring but as far as box info what kind of box do you have and if its going on protect mode you need to turn your system down bkz your running to much juice. either that or you have a short somewhere
Nov 16, 2008 | Directed 3124 Car Subwoofer
Power Acoustik P312W Car Subwoofer Logo
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
