Question about Panasonic KX-TA824PK Phone
Ring need only 1 phone, how can this
We are installing 8 x 24 panasonic pbx, but incoming calls come ringing all telephone(24 line ring together) . no need like this type ring , how to create ringing only main phone ext.101,
can u help me please give me details , how to do me, p
thanks
karim
  • amdeyes Jul 19, 2010
    I have the same problem, Does anyone has a solution?
    Amde from Ethiopia
  • Panasonic Master
  • 2,460 Answers
Unless someone stripped the documentation from the product, there's a set of manuals and a CD with programming software in the box. In a system as complex as this, couldn't you at least take the time to open one or the other and read? At the very least, start at page 10 of the PROGRAMMING manual (PT programming) and it will tell you how to set the date and time. Pay attention to system programs 400 and 408-410. That's where you tell the sytsem how many lines and where they ring.
Carl
Posted on May 29, 2010
How to i turn on Caller ID on my panasonic kx-dt321 phone ? When an incoming caller rings it just says Line 1 . No number is displayed.The 3 other similar phones all have caller ID when someone rings
If I understood users manual which I found via internet,it is digital system for PBX,so it means you can use it 100% if it is programed thru PBX system,so you need to call your IT personel to program it
for you.
Aug 30, 2017 | Panasonic Lands Phones
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
I have 10 Panasonic KX-T7730 using 8 phone lines. I've confirmed with AT&T that all 8 lines are setup for caller ID. I've confirmed that all 8 extensions have the Caller ID enabled. Two of the
Firstly, you have not indicated which phone system your phones are connected to, e.g. KX-TA824, KX-TDA50 or other, so I'm a little in the dark. That being said, most of the Panasonic Systems only display Caller ID information (CID) to phones that are programmed to "Ring" on the line with the incoming call, and the line button flashes green to show it's ringing... so you must "system program" ringing for the line(s) on each phone. If the CID is not displayed on a particular phone, then that line is likely not programed to ring on that phone (it's light may flash red instead of green). After you "system program" the line to ring, you can still shut off the ringing sound on a phone using the slide switch on the left edge of the phone if you don't want to hear ringing, and this will not interfere with the CID display. Also, on a second note, CID does not display on the first ring coming in from the phone company (TELCO). The CID signal is sent from the TELCO to your system after the first ring has ended, during what would be the silence period that would occur before the second ring, if there was no CID. It is for that reason that most knowledgeable installers program lines with a five second delayed ring; in this way, you don't know the call has arrived until after enough time has passed for your system to receive the CID signal... this is why it seems the CID appears instantly, with an incoming call. Check out the line programming for each line and set it to ring with a 5 second delay. If you don't set up a delay, your phones will ring and if you answer the call immediately, its likely it won't allow the system to receive CID, so no CID will be displayed for that call.
Oct 28, 2014 | Panasonic KX-T7730 Corded Phone
TD-1232 PBX - is is a programming issue or hardware issue?
ok so the first thing you should do is to get to where your PB X connects to the lines and ensure that there is a standing voltage on the lines. usually 50 v dc in the uk.
check each line has 50 volts with a multimeter when nthey are not active.
if line 3 has no voltage your problem is the line.
if line 3 does have voltage at 50 v idle ring the lines out 1 then 2 then 3 foir a analogue line to present ringing bthe voltage increases and is in cadence with the ringing. if again the voltage does not increase during the ringing cycle then the problemn is again with the line.
if the line 3 has 50 v idle and increase in voltage during ringing, then the problem is the line interface in the PBX
hope that this helps all above is for analogue lines only
Mar 10, 2017 | Panasonic Kx-td1232 Super Hybrid Pbx...
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
We have three lines incoming. when line 1 is busy the second call on line 2 will not ring on other extensions.we have 4 extensions but call goes straight to the answering service on extension 5. Is this a...
This could be a setup problem, however I suspect you may have a "smart ring" set up with the telephone company. If this is so then it won't work. If the 3 lines are dedicated, then there is something wrong with the PBX.
Oct 04, 2010 | Office Equipment & Supplies
On 308 pansonic pbx (kx-t7730), when the incoming call rings all the extension phone and the master (PT or operating console)phone rings.so please help me to make it ring only on the master.thanks
When you take this unit out of the box, you get programming instructions. One of them is the ringing (program 408) for day mode. (409/410 for night and lunch). By default, all phones ring on all lines in all 3 modes. You have to remove the ring to make it go away.
Carl
Sep 29, 2010 | Panasonic KX-T7730 Corded Phone
I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP -PBX PHONE SYSTEM WITH PANASONIC PHONES KX-T7633 PHONES.WE HAVE NINE PHONES IN THE OFFICE AND I CAN ONLY GET 1 TO RING ON INCOMMING CALL HOW DO I GET ALL...
In program no (620) enter all the extension nos which you want to ring in group 1. Then in program no (450) enter the floating no of group 1. You will get the floating no in program no (623).
Mar 23, 2009 | Panasonic KX-T7633 Corded Phone
Set not ringing
When you say you are the one responsible for the programming, are you referring to programming the "physical phone" or the PBX and line cards and system functionality?
You should have an extension on your phone. Has that extension for example 222 been translated at the PBX to ring on a direct number -> (xxx) 555-1222
Or by what you are describing, you are more looking at having "shared lines" that ring in multiple locations simultaneously, and once picked up somewhere a "line lock" should be in place?
Aug 13, 2008 | NorStar M7310 Corded Phone
Panasonic KX-TA824PK Phone Logo
159 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
