Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
I am desperately trying to change my HD to a file system FAT32, now i know the deal in doing something like this and have tried different ways in doing so. Unfortunately each solution always ends in one problem either my HD is too small or not supported. I have tried going to WD itself and downloaded the utility to do just that but as i said before it said my HD was too small or not supported. So PLEASE! can someone help me find a solution, is there some kind of easy to use software out there that doesn't back out on me or something
    Scholar:
  • 94 Answers
The system FAT32 is for windows 95 to 2000 and ME only. If your using Windows XP, Vista or windows 7 the system format is NTFS. So you need to reformat your HD (Hard Disk) into system NTFS.
Posted on May 29, 2010
  • 44 Answers
You have to know that in order to have a HDD formatted with FAT32 the space must not exceed 32GB. so you need to partition your HD into two logical hard-drives then have one of the partitions in the size of anything less than 32GB, then simply reformat using FAT32 attributes.
If you are using windows vista, then its super easy to partition and format your external HD while logged on. if you need more instructions on how to do this, let me know.
Hope that helps.
Trying to put 6.56GB movie on my 8GB sandisk cruzer contour, says the file is too large for the destination file
The file system is likely the culprit for this. If you've formatted the USB stick with FAT32, the largest SINGLE file will be about 4GB. You can place as many smaller files as you want to fill the stick completely (in excess of 4GB), but once you approach 4GB for a single file - it will crash.
Format with NTFS instead. No 4GB limit is placed on files in this file system. A nice chart listing the differences between file systems can be found here. The forth row "Max File Size" shows the data you're asking about. NTFS supports 16TB (terrabytes are 1000 times larger than gigabytes) while FAT32 is limited to a "paltry" 4GB. Both FAT32 and NTFS are supported by Windows XP and newer OSes.
I hope this helps - please rate my reply - thanks!
Dec 28, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
Wanted to use external hard drive on ps3 so downloaded fat32 on hd. Now pc wont read hd aswell as ps3.
You can't "download fat32". What you have probably done is formatted the disk as fat32 (which is standard anyway) which will have wiped the drive. You should still be able to acccess it but there will be nothing on it.
Nov 08, 2009 | Cars & Trucks
Reformat my external drive to NTFS
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Hope this helps you out.
Jul 15, 2009 | Western Digital My Book Essential Edition...
When I plug in my 320GB My Passport Western
It seems your HDs left over portion which is not showing is not formatted for the particular OS in which you are trying to copy. It is advised to backup your HD contents and format the HD with the OS from which you want to take data in the same FAT system which that OS is using.
Jun 15, 2009 | Western Digital Passport 320GB External...
Is it possible to install 2nd 0/s on separate hard drive 40gb,id not sata attached via usb with laptop of dell inspiron 1525 c2d give steps to install
It depends what kind of SO do you want to install
I recommend you to user an USB Linux distro.
Anyway, normally when installing any SO lets you select the partition where you want to install the SO.
Select the partition belonging to the USB External HD, and do everything else normally.
You must have in mind that you will lose everything in the USB HD, and that using it this way the OS will work only when the HD is plugged to the same PC, it may work with a different PC with different hardware but the SO will install the new drivers for the new hardware.
That's why I recommend you to use linux, check this out www.pendrivelinux.com/
Mar 19, 2009 | Microsoft Windows 98 for PC
JVC KW-AVX815 Player USB Source does not recognize 2.5'' HD
i got my portable drive to work by partitioning to 127gig fat 32 only the old fat32 not the vista version it wont read above that or recognize files if you make it larger
Nov 19, 2008 | JVC KW-AVX810 Car DVD Player
Cant download large files to my book
Try converting from FAT32 to NTFS. That should take care of the problem. Check out http://support.microsoft.com/kb/314097/EN-US/ for the XP instructions.
Oct 23, 2007 | Western Digital My Book Essential Edition...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
201 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
