I had to move everything and now i can not find where do i plug it into.....the linkseys blue wire with the clear plug in....where does it plug into
  • 236 Answers
I'm assuming you mean the internet wires... The one from the wall goes into the modem provided by your ISP (internet service provider) (should be the slot at the very bottom).. :
A) From there, if you have a router, one must go from the modem to the "modem" input on your router.. From there, plug in the cord in either slot 1,2,3,4 and connect it to the back of your computer (it will only fit in one slot).
B) If you do not have a router, just plug the other cord into the top of the modem, and then connect that to the back of the computer.
Posted on Apr 08, 2008
How to check for spark
Here are some ways that I use on a regular basis as follows:
1.Remove the plug wire, insert a screwdriver/plier/metal object that has a thick rubber/plastic handle (as you can be shocked through a thin handle). Hold the metal of the tool, about 1/4" away from an engine ground (intake manifold, egr pipe, ac hose, bolt, etc). Be sure that everything is clear off moving parts. Attempt to start the engine (you may need a helper) and observe a spark between the tool, and the engine ground (should be blue).
2. Using a 12 volt test light (available at auto parts store for $5) connect the lead to a ground or the negative (-) post of the battery. Locate your spark plugs, then insert the probe into the spark plug boot. Attempt to start the vehicle, the light should blink rapidly.
on Jan 12, 2010 | Mitsubishi Mighty Max Cars & Trucks
Trying to replace the start relay on my Roper refrigerator.
depending on the model and the part # of the ptc overload relay will tell you how to wire it back as was,on some ptc O/L's there are spaces on the component where you just plug it on piggyback to this ptc,if not then all you do is wire the capacitor in parallel to the 2 power pins on the compressor,the cap doesn't actually start or run the units compressor,its there to help suppress the arcs on the relay when it starts,the compressor will operate without this capacitor
May 07, 2012 | Roper Refrigerators
Two problems...1) I have a faint blue horizontal line that is moving from bottom to top. It is rather distracting. I also am getting a lot of feedback in the desktop speakers. The light green wire is...
try the monitor on another PC, be super simple and ends 1/2 the possibles is 5 min works and what we cant do here.
bad cable? is my wild guess.
feedback (with no mic?) or just noise, feedback is squealing.
with the green jack speaker wire pulled is the screen ok now?
Dec 05, 2017 | HP W19b LCD Monitor
I need step by step instructions on how to install defrost thermostat for model # GSS20IEPWW side by sideRefrigerator?
Empty the freezer. Unplug the fridge. Take all the shelves and drawer out of the freezer. Remove the lightbulb cover and bulb. Take out the screws that hold the panel on the back of the freezer wall. Slide the panel up slightly to clear the thermistor housing (a small 'bump' on the bottom left side) and remove the panel pulling from the left side forward. The defrost heater is on the bottom of the coils held on by two screws, and the thermostat is clipped on to the top coil and has pink and blue (sometimes orange) wires going to it. Don't worry if the wire colors on the new one are not the same. Unclip the thermostat and cut the wires, leaving yourself enough wire to strip them back and connect them with the new ones. Use crimp connectors or wire nuts (for wet applications) and then clip the thermostat back on. To replace the defrost heater, remove the two screws and disconnect the wires. The new defroster might have both wires on one side, rather than one on each side. That's okay, just move the wire on the left over to the right along side the other wire, and connect. Put everything back together, and plug back in.
Dec 31, 2010 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
30 inch philips tv 30pf9975 /17. Gets sound but only blue screen through component hookups. Sometimes works all day but intermittenely gets blue screen.
dear i think there is a fault in your moniter cable means the two cables red and green is broke down or damage inside the plastic cotted wire.sometime when u move the wire the broken ends of the cable meets and u get clear result but when they disconnect u get blue screen
Nov 05, 2009 | Philips 30PF9975/17 Monitor
Keep getting dns error,for couple of days then works fine then starts again ?
if u have your own internet connection then you have to see if the modum is intact bc mine used to do that and i found out there was a wire loose and i fixed if ur using wifi and maybe like a neighboors connection like linkseys or default or etc.. then they might be moving somethings around which causes the internet to go on and off
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
12 years old rear projection, the blue + won't move left
First check that no resistors are burnt near the convergence ICs, of course with the back open. Next tap on the metal heatsink and see if the blue pops straight, if it does you could just solder the pins on the IC nearest the blue convergence yoke plug, soldering is a trained skill and would involve pulling the chassis back and flipping it upward without breaking any wires or components. If you see discolored resistors in the right section the ICs are shorted and need replacing.
If nothing is loose and everything looks OK, you may have a bad remote button (probably not, but hey) . as a last resort you could try moving the blue yoke centering tabs, this would move all the blue at once so if its bowed anywhere it would not solve your issue. If this helps great , if not post more info for more help.
Aug 17, 2009 | Hitachi Televison & Video
Adding extra wire to speakers so I can move speakers.
Red and black are high end and blue and grey are sub speakers.
Apr 15, 2017 | Panasonic SC-AK500 CD Shelf System
Power surge on hub port on my computer
Try unplugging everything from the hub and if that doesn't work then disable the hub.
You can either buy a new hub or buy a USB card. Both get the same results.
Oct 22, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
