I'm having trouble getting a picture on my soniq hd tv. I'm not sure if i have the cables in the correct outlets
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please switch off the TV and pull off all the connections from/to the TV connected with any other source. Switch it on at least after 1 hour to drain off the current from all the components especially capacitors before you perform any test or repair. Also note that the TV consists of very high voltages even when it is in OFF condition. Now please check that all the cable wires are fine and connected properly with the TV and cable box or any other device. Also please check that the inverter and back light are fine. If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components of your TV. Replace whichever has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 29, 2010
How can I use headphones wit a Soniq S55UV16B-AU Smart TV?
You have to use wired headphones and plug them in.
https://www.jbhifi.com.au/tv-home-entertainment/hd-televisions/soniq/soniq-s55uv16b-55-uhd-smart-led-lcd-tv/316772/
Component Inputs - 1
RCA Inputs - 1
RF Input - True
Headphone Output (3.5mm) - True
Energy Star Rating - 3.5
Product Height with Stand (mm) - 782.7
Product Width with Stand (mm) - 1240.6
Soniq S55UV16B
Sep 23, 2017 | Televison & Video
How to connect a pc to soniq qsp425t
you will need the proper tv remote ...from the factory
Nov 16, 2013 | Televison & Video
My tv has picture but no sound
Here are some steps you can take to help restore the sound on your TV:
First check the mute button and volume setting to make sure they are correct.
Next, check the connections and make sure they are tight. Check all of the cables for damage and make sure they are connected to the correct outlets.
Try replacing older cables with new ones and see if that works.
Finally, test another input, such as a radio or CD player to see if the problem is with the TV or the sound system.
For more troubleshooting helps and potential solutions, check out the handy chart at No sound on TV. I hope this helps!
Sep 12, 2012 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
I have a Vizio 55" TV model M55ONV. I can't
Are you using a cable box like a DVR?...there should be a setting on that for aspect ratio, not sure this is a TV issue
Dec 18, 2017 | Televison & Video
Hey guys i gave my ps3 to a shop in st neots to get my hd working and he blew out all the dust with a air gun and changed the settings and said the ps3 is set up for hd now and it worked on the shop tv but...
When changing the display mode of the PS3 you must be in the correct mode and be using the correct wire. If in the shop it was last set up in HD mode, then you must be using an HD cable (component cable(wire with red/yellow/white) will not work. Also, make sure that your TV can handle the resolution it is set in. If your TV at best handles 720p and the PS3 is set in 1080, then you will have to hook it up to a TV with 1080 to change it back or you will not get a picture.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
HD Camcorder to Sony HDTV using Component Cables
in order to send hd video to your HDTV, you will need to use a hdmi cable. If you are planning to use component cables make sure you have component output from camcorder..still it is not HD.
Dec 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No sound from speakers when tv is on
It is likely that you do not have an HDMI cable connecting your cable/satelite set top box to the reciever. If you you run coxial striaght to your TV you will need a digital tuner and run the audio componet cable to the receiver and picture cable to the TV. Also be sure that TV out is perferably with optical audio. Hope this helps. If not its all listed simply in the owners manual. Try Sony's website if you lost it.
Apr 05, 2009 | Sony HT-SS2000 Theater System
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Mar 27, 2008 | Televison & Video
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
